Maya Animation and Rigging
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
Joint question
5 REPLIES 5
743 Views, 5 Replies
Joint question
Hello, I try go get the joints smaller than this, but 0.01 is the smallest size I can get. Is there a way to override the joint size?
5 REPLIES 5
mspeer
Hi!
You can set the "Display Scale" manual to any value you want even "0.001",
you can also set "Radius" individual for every joint.
in reply to: mspeer
Hi and thanks for your reply. I cant really seem to fix my jointsize issue, so I need to re-rigg her. Ill probably go for a spine rigg this time, which seems to be the most common used method these days.
gautham.chandran47
Joints size doesn't have any effect on the rigging process, its just for visual.
Goutham Chandran
Cinematic Animator | Rockstar Games
Linkedin | Instagram | Facebook
mspeer
Hi!
No need to re-rig,
please upload a scene-file.
in reply to: mspeer
A actual solution would be to hide the joints completely and just use the search in the outliner to find the joints I want.
