Hello,I have been having an issue with animating my facial nurb circles separate from the GUI I have set up. I would like to find a way to animate it both ways. Thank you.
I want to animate my facial controls without using the slider, but while keeping it at the same time
Right now I am unable to animate the facial rigs unless I use the slider that I set the driven key to. I want to be able to animate both the facial rigs and sliders for animation.
I also noticed blue tags near the translate attributes in the channel box for the NURBS that I have set a driven key to.
I hope that makes sense
The slider you are mentioned is the one that has blue shade in it? If yes then you shouldn't animate those. That blue shade means there is a set driven key assigned to that. Animate the controller that was the parent when you created the set driven key. If not then please mention how you want to animate it without using the slider.
