Hi!
I have an alembic cache of a conveyor belt moving, and I have a static jar that I want to fall onto the belt and start moving along with it. When I tried the bullet system, I made the jar a active body, and the conveyor and dynamic rigid body (I made sure it wasn't on static). But nothing is working so far. Does anyone know how I would approach this?
Solved by rajasekaransurjen. Go to Solution.
Try Rivet.
Select two edges and call rivet it will create a locator on the polygon. The locator is move along with the polygon.
Constraint the jar with the locator.
// Copyright (C) 2000-2001 Michael Bazhutkin - Copyright (C) 2000 studio Klassika // www.geocites.com/bazhutkin // bazhutkin@mail.ru // // Rivet (button) 1.0 // Script File // MODIFY THIS AT YOUR OWN RISK // // Creation Date: April 13, 2001 // // // Description: // Use "Rivet" to constrain locator to polygon or NURBS surfaces // Select two edges on polygon object // or select one point on NURBS surface and call rivet // Parent your rivets and buttons to this locator global proc string rivet ( ) { string $nameObject; string $namePOSI; string $parts[]; string $list[] = `filterExpand -sm 32`; int $size = size($list); if ($size > 0) { if ($size != 2) { error("No two edges selected"); return ""; } tokenize($list[0],".",$parts); $nameObject = $parts[0]; tokenize($list[0],"[]",$parts); float $e1 = $parts[1]; tokenize($list[1],"[]",$parts); float $e2 = $parts[1]; string $nameCFME1 = `createNode curveFromMeshEdge -n "rivetCurveFromMeshEdge1"`; setAttr ".ihi" 1; setAttr ".ei[0]" $e1; string $nameCFME2 = `createNode curveFromMeshEdge -n "rivetCurveFromMeshEdge2"`; setAttr ".ihi" 1; setAttr ".ei[0]" $e2; string $nameLoft = `createNode loft -n "rivetLoft1"`; setAttr -s 2 ".ic"; setAttr ".u" yes; setAttr ".rsn" yes; $namePOSI = `createNode pointOnSurfaceInfo -n "rivetPointOnSurfaceInfo1"`; setAttr ".turnOnPercentage" 1; setAttr ".parameterU" 0.5; setAttr ".parameterV" 0.5; connectAttr -f ($nameLoft + ".os") ($namePOSI + ".is"); connectAttr ($nameCFME1 + ".oc") ($nameLoft + ".ic[0]"); connectAttr ($nameCFME2 + ".oc") ($nameLoft + ".ic[1]"); connectAttr ($nameObject + ".w") ($nameCFME1 + ".im"); connectAttr ($nameObject + ".w") ($nameCFME2 + ".im"); } else { $list = `filterExpand -sm 41`; $size = size($list); if ($size > 0) { if ($size != 1) { error("No one point selected"); return ""; } tokenize($list[0],".",$parts); $nameObject = $parts[0]; tokenize($list[0],"[]",$parts); float $u = $parts[1]; float $v = $parts[2]; $namePOSI = `createNode pointOnSurfaceInfo -n "rivetPointOnSurfaceInfo1"`; setAttr ".turnOnPercentage" 0; setAttr ".parameterU" $u; setAttr ".parameterV" $v; connectAttr -f ($nameObject + ".ws") ($namePOSI + ".is"); } else { error("No edges or point selected"); return ""; } } string $nameLocator = `createNode transform -n "rivet1"`; createNode locator -n ($nameLocator + "Shape") -p $nameLocator; string $nameAC = `createNode aimConstraint -p $nameLocator -n ($nameLocator + "_rivetAimConstraint1")`; setAttr ".tg[0].tw" 1; setAttr ".a" -type "double3" 0 1 0; setAttr ".u" -type "double3" 0 0 1; setAttr -k off ".v"; setAttr -k off ".tx"; setAttr -k off ".ty"; setAttr -k off ".tz"; setAttr -k off ".rx"; setAttr -k off ".ry"; setAttr -k off ".rz"; setAttr -k off ".sx"; setAttr -k off ".sy"; setAttr -k off ".sz"; connectAttr ($namePOSI + ".position") ($nameLocator + ".translate"); connectAttr ($namePOSI + ".n") ($nameAC + ".tg[0].tt"); connectAttr ($namePOSI + ".tv") ($nameAC + ".wu"); connectAttr ($nameAC + ".crx") ($nameLocator + ".rx"); connectAttr ($nameAC + ".cry") ($nameLocator + ".ry"); connectAttr ($nameAC + ".crz") ($nameLocator + ".rz"); select -r $nameLocator; return ($nameLocator); } rivet;
