Announcements
HotKey for hiding Joint preview
gautham.chandran47
gautham.chandran47
Its not much job but its annoying to evey time hide the joint visibility by going to show > and toggle joints.
I was wondering if there is any way to do this using hotkey or a custom script from the shelf .
Goutham Chandran
Cinematic Animator | Rockstar Games
Linkedin | Instagram | Facebook
Replies (8)
mspeer
Hi!
Use "Echo all Commands" in Script Editor to see the right command and assign this to a hotkey with Hotkey Editor.
But the show command of the Viewport will only work for one specific window/Viewport.
You may better use (MEL):
hideShow -joints -hide;
hideShow -joints -show;
gautham.chandran47
Thank you.
Goutham Chandran
ajzec
How to do it on one hotkey?
ZigaPokorn3479
i have this command bound to a hotkey
dR_DoCmd("viewJointsTGL")
ajzec
Thank you!
marshallNCN8W
Thanks for this. Any wonder why such a basic function is not easily accessible.
Curious what your solution would be to just toggle visibility for all kinematics?
Trying to keep the viewport window uncluttered is becoming more of a task these days.
Thank you again.
OGRigger
Observer
Observer
pan =cmds.getPanel(  type='modelPanel') #gets all panels
if (cmds.modelEditor( pan[-1], q=1, j=1)): # using Echo commands on u can find number of your panel
    cmds.modelEditor(pan[-1], e=1, j=0)
else:
    cmds.modelEditor(pan[-1],e=1, j=1)
Here is python v if needed
lzachariasCKXEV
Community Visitor
Community Visitor
Alternatively to scripting methods, you can use the hotkey editor to search "View Joints TGL" and assign it to whatever input you want, personally use alt 3, since alt 1 toggles curves vis and alt 2 toggles geo vis. Remember to save a hotkey set so it is there next time you open maya
