Maya Animation and Rigging
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
HotKey for hiding Joint preview
8 REPLIES 8
Message 1 of 9
gautham.chandran47
4415 Views, 8 Replies
Its not much job but its annoying to evey time hide the joint visibility by going to show > and toggle joints.
I was wondering if there is any way to do this using hotkey or a custom script from the shelf .
Goutham Chandran
Cinematic Animator | Rockstar Games
Linkedin | Instagram | Facebook
8 REPLIES 8
Message 2 of 9
mspeer
in reply to: gautham.chandran47
Hi!
Use "Echo all Commands" in Script Editor to see the right command and assign this to a hotkey with Hotkey Editor.
But the show command of the Viewport will only work for one specific window/Viewport.
You may better use (MEL):
hideShow -joints -hide;
hideShow -joints -show;
Message 3 of 9
gautham.chandran47
in reply to: mspeer
Thank you.
Goutham Chandran
Message 4 of 9
ajzec
in reply to: mspeer
How to do it on one hotkey?
Message 5 of 9
ZigaPokorn3479
in reply to: ajzec
i have this command bound to a hotkey
dR_DoCmd("viewJointsTGL")
Message 6 of 9
ajzec
in reply to: ZigaPokorn3479
Thank you!
Message 7 of 9
Thanks for this. Any wonder why such a basic function is not easily accessible.
Curious what your solution would be to just toggle visibility for all kinematics?
Trying to keep the viewport window uncluttered is becoming more of a task these days.
Thank you again.
Message 8 of 9
pan =cmds.getPanel(  type='modelPanel') #gets all panels
if (cmds.modelEditor( pan[-1], q=1, j=1)): # using Echo commands on u can find number of your panel
    cmds.modelEditor(pan[-1], e=1, j=0)
else:
    cmds.modelEditor(pan[-1],e=1, j=1)
Here is python v if needed
Message 9 of 9
Alternatively to scripting methods, you can use the hotkey editor to search "View Joints TGL" and assign it to whatever input you want, personally use alt 3, since alt 1 toggles curves vis and alt 2 toggles geo vis. Remember to save a hotkey set so it is there next time you open maya
