Maya Animation and Rigging
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
Graph editor bug
1 REPLY 1
avaliquet1
154 Views, 1 Reply
Graph editor bug
I recently downloaded maya 2025 on my macbook pro and so far i havent had many problems. However, today, as im trying to use my graphic editor, my some of the keyframes i had put on my object simply do not appear or my tangents are all completely broken.
I thought my file was corrupted so i opened up a fresh file and simply animated a cube going left to right.
In the image linked to this post, there is supposed to be two keyframes, on frame 1 and on frame 15. However, the keyframe on 15 is non existent and is replaced by a weird white line. Furthermore, i cannot see the curve of my tangent which should simply be a default ease in ease out curve.
How can i fix this? I have had no trouble using the graph editor until now and i havent changed my settings since the last time i've used the graph editor with no issue.
Thank you in advance!
Labels (5)
1 REPLY 1
jmreinhart
in reply to: avaliquet1
Are you able to test with other Maya versions? That way we can figure out if it is just a 2025 issue.
Have you tried updating your drivers?
