Maya Animation and Rigging
Welcome to Autodeskā€™s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
Showing results forĀ
Did you mean:Ā
Flipping, Motion Path
2 REPLIES 2
dg3duy
196 Views, 2 Replies
This happens to me every time I make a tour of an object and it rotates 360 degrees, it loses the orientation, what methods can be used so that the flipping does not appear. I attach the scene.
https://www.mediafire.com/file/oabgn56szszzkc8/Cone.ma/file
2 REPLIES 2
dave.cooleyVKJNJ
in reply to: dg3duy
This can be frustrating. But for this example, there is a simple solution.
Create a locator and place it in the center of the loop.
You can set this up in the options before creating the motionpath, but if you already have the motionPath node, you can edit it now.
Change the World Up Type to Object Up.
There will be a new World Up Object empty space. copy and paste the name of the locator (i.e. locator1).
When you play it back, the cone will always aim at the locator during the loop.
dg3duy
in reply to: dg3duy
Very good! it worked perfectly in this case.
Thank you very much
Technology Administrators
