I'm really new to Maya, so this most likely has an obvious answer. But I have a mesh that I downloaded with the .3ds file extension. I managed to import it into Maya and used autoRig to rig it, but when I try to make it an active or passive collider with bullet physics it throws this error (Null1 is the name of the mesh): # Error: line 1: RuntimeError: file C:\Program Files\Autodesk\Maya2023\Python\lib\site-packages\maya\app\mayabullet\RigidBody.py line 105: The attribute 'Null1.translateX' is locked and cannot be connected.
I imagine this is because the rig locked it for some reason, but I don't know how to fix it.
If it isn't fixable, is there another solution? I tried to use active and passive bodies in the fields/solvers tab, which also doesn't work.
Solved by dasilvagMCKWY. Go to Solution.
