Hi
I am trying to add a blend shape node to a set of selected meshes. I get the error "// Error: line 0: Target polySurfaceShape1 does not match with base hulkShape."
What does this mean? Why it won't allow me to add a blend shape node?
Solved by stephenkmann. Go to Solution.
If you are 100% sure that your target shape matches topology with your base shape.
then it's probably that you aren't choosing the blendShape node in the edit Blend shape ui
Try choosing the blendNode in the UI
-=s
How do I do that?
I choose the 3 meshes that are differing somehow. Finally I choose the base mesh, the one with the BlendShape node attached to it and go to Deform-> Blend Shape -> Add. I choose the node and I get the error message I explain at my first thread.
How do I do otherwise?
Sounds like your model topology is different on one of you targets.
try making a new blendShape with each target. *( this is just temporary to find the bad target )
Sometimes I'll just duplicate my base for testing.. but really you can just do all this then Not save the file.
You're doing this just to find out which model doesn't match, and why.
Whatever model is polySurfaceShape1 is the one that doesn't match.
Are all your targets duplicates of the original base mesh?
Did you do any topology changes to the targets?
For blendShapes to work correctly (and easily) the topology should be exactly the same for the targets as the base mesh
hth
-=s
Well,
Yes, al targets are copies from original base mesh.
PolySurfaceShape1 there is not such an element with that name. There is a mesh named "PolySurface1" which is referring to a small part of the character's hair. As far as I am concerned, I don't remember to have modified its hair since I want to blend them for eye movements.
I did topology changes. I modified the eye space, to be half and full shut (close/open). How, else to make them blend? Those topology changes need to be done. Otherwise, why to do blending?
topology changes refers to changing vert, face, edges counts. .deleting edges, adding edges. split poly, smoothing, etc. Not the moving of the points around.( that's expected to happen)
PolySurfaceShape1 was mentioned in your error. but your response is curious.
First off. I would name all your geo.
second. Do you have geo parented under other geo?
It's generally not advised to parent geo under other geo. ( especially when you are just learning and haven't figured out all the nuances of how this all works)
If you blendShape groups.. which is okay to do, you want the order of objects in the groups to be identical.
If they have different orders, then it won't try and blend the correct targets to the right base meshes.
hth
--=s
