I am a student who with completely zeroknowledge in MAYA,following youtuber where they clicked on without understanding the function and control in maya..... hope anyone can help me with this
I select the Output and try to connect with the input one with bending, so before i click on the input, the "curvature" is not highlighted seems like it cannot be connected, and i click on it, yes it was not connected, why i cant connect my Bend Output(Attribute i custom added) to "curvature" input in bend function
Judging from your screenshot, it seems you HAVE connected those. You start with Output side and select the attribute - the right Inputs side reacts on this by higlighting/grayingout inputs, depending on what you have selected, e.g. you can't connect Output.translateX to Input.translate, yet you can connect it with bend1.curvature
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the ACCEPT SOLUTION button, so others might find it much more easily.
act before i "connect" like in the screenshot, when i select bend on the Left(Output), the " curvature" not highlighted in Right (input) and it seems cant be connect with, the screenshot show like it connected because i clicked on the Not highlighted "curvature"
The Maya Help explains the CE behavior:
Connected attributes in the Connection Editor appear in italics (Mac OS X excepted), while non-keyable attributes appear dimmed. Some dimmed attributes indicate a nested list of attributes.
You were trying to connect the attributive that was already involved in connection - bend1Handle.curvature to the bend1.curvature .. From what was said above, the connected attributes are displayed in italics, not locked. When the attribute is locked, you get a Warning and no connection is made.
,,,_°(O__O)°_,,,
