Hello there, So I was finally managing to do the whole rig (including fingers and weight painting), when suddendly my pc blue screens out of nowhere. Luckily it did the save the files but for some reason, when I am trying to use the controls, they won't move, at all. I am really confused by this, I really hope I don't have to do the whole rig again because if so I might go crazy.
Would gladly accept any help on this matter.
Solved by mspeer. Go to Solution.
Hi!
The Skeleton Definition is broken.
Switch to the Definition tab and unlock the Skeleton Definition, then assign the right hand joint (and the fingers for both hands if you need them there too) and create a new control rig.
(You will not loose the painted weights).
😮 Hi there, sorry for the late response, yes it worked, thank you very much!
