Specified weight could not be set due to locked influences
Message 1 of 16
hello everyone i have problem doing paint weight . it show warning "specified weight could not be set due to locked influences" .. any idea how to "Unlock" this  ? .
i read other forum about this issue .. he said : "in the paint skin weights dialog box, move down the list and see what bones/influences have (hold) written right next to them. Select the joint in the list and click "Toggle Hold Weights On Selected".
what does he means ? i cant find how to do this in my paint skin weight dialog box
Replies (15)
Message 2 of 16
gautham.chandran47
Select the skinned mesh and go to paint weight tool and you can see the influences in the "paint skin weight tool" window.
Find the joint which is locked . It will show a yellow locked icon on the left, here its all unlocked and grey. Left click on it to make it unlocked.
Goutham Chandran
Cinematic Animator | Rockstar Games
Linkedin | Instagram | Facebook
Message 3 of 16
hye mate , thank you for your respond ..
yes .. i already checked and unlock every joints but still have same warning ..
did i skip something ? Screen Shot 2017-12-19 at 10.09.47 AM.pngScreen Shot 2017-12-19 at 10.10.08 AM.png
Message 4 of 16
just discovered something . i tried open my project file to other PC , and everything is fine .
so maybe my maya 2017 is problem . so i uninstalled then installed again . but it still show the warning mesage.
any idea what should i do ?
Message 5 of 16
mspeer
Hi!
You installed the latest update for Maya 2017?
Message 6 of 16
hello ,
Yes i already update to update 3 .
Message 7 of 16
mspeer
Hi!
Latest is update 5.
Message 8 of 16
hi ,
ya now i already update to latest update 5 ..
i open my project file to other PC with maya 2017 basic with no update , the paint weight is working normally ..
is it my mac not support to do this ? because i create new project and did a simple rig , still the have the same warning .
thank you for ur respond btw
Message 9 of 16
mspeer
Hi!
Try a reset of your preferences.
Rename the folder prefs in folder 2017 to something like prefs_backup, or to reset everything, the folder 2017 to 2017_backup (or even the maya folder to maya_backup). Maya creates new folders (don't copy preferences from previous Maya versions). Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
Message 10 of 16
hi,
i follow all ur steps and the link given.. and its still not working . but it fixed other warning msg .
thank you btw . 🙂
Message 11 of 16
mspeer
Hi!
Please provide an example scene with a simple rig that does not work for you.
Message 12 of 16
samdbeeman
Observer
Observer
Hi!
For future reference, this problem can be fixed via skin > edit influences > set max influences and then increasing the number.
Essentially, every vert can only be influenced by a set number of joints. The default is 4 or 5, but for really smooth deformations this might not be enough.
Message 13 of 16
mfortmue
Community Visitor
Community Visitor
Thanks!!! I was just having this problem and would have never come up with this solution.
Message 14 of 16
LandArmor
I figured it out. Try to change attribute "Max Influences" to 2 or more in skinCluster node.
Message 15 of 16
delacruz_correaQ8SH7
Community Visitor
Community Visitor
This helps even in Maya 2025...
Message 16 of 16
delvin_dupre
Community Visitor
Community Visitor
I've tried all these, and I still have this issue
