Rigging an object for bounce animation
I'm very new to Maya, and trying to animate a shoe sole (which I've imported from Rhino --> Maya as an iges file–– see attached screenshot) bouncing on a plane. I'm wondering how would be the best way to rig the entire sole so I can animate the entirety of the object bouncing like a rubber ball. I'm wondering if there is a good way to treat individual layers/components as one unit, so different parts of the object aren't moving independently of others.
gautham.chandran47
If its more than one mesh, then group all.
Select that group and go to " Deform > Non-linear> Squash "
You can control the squash under the "squash settings " in the "channel box" by manipulating the "factor".
Hope this helps.
NOTE: YOU MIGHT WANT TO ROTATE THE OBJECT TO THE DIRECTION YOU WANT IT TO SQUASH OR YOU CAN ADJUST IT IN THE SETTINGS FROM CHANNEL BOX.
Goutham Chandran
Cinematic Animator | Rockstar Games
Linkedin | Instagram | Facebook
