Renaming xGen Collections and descriptions.
joaosacadura
joaosacadura
Hello. I am working on a project where i had lots of trials and errors getting xgen to work and do what I wanted. As a result my xGen files have names that I don't want in my final project. Is there a correct way to change the names of both without messing the project? (i know xgen is a bit sensitive about folders and names).
I tried to rename the descriptions on the outliner and it seemed to work, but the Collections doesn't work that way.
Thanks.
sean.heasley
Hi @joaosacadura and welcome to the community!
It is possibly but generally I wouldn't recommend it because like you said Xgen can be very finnicky when it comes to names of files, naming conventions etc.
This thread for example went over the process of changing the name of an Xgen mesh and it's pretty c...
That said, is it just the collection you want to rename or are there other parts as well?
sean.heasley
Hi @joaosacadura
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
joaosacadura
We decided to just let it be as it was. No need to take risks
