Problem with rescaling a rigged character
Hello, as I wrote, I can't find a way to scale one of my rigged characters. For others, I used the method of rescaling by finding the main transformer in Hypergraph Hierarchy, but in the case of this one, it's just not there. Can someone look it up?
Thank You.
Rigged Character File
gautham.chandran47
The attached link is private, I've sent a request for access.
If it's a simple rig you can group everything except mesh and scale that group.
Hope this helps.
Goutham Chandran
Cinematic Animator | Rockstar Games
Linkedin | Instagram | Facebook
I’ve granted u access in case it is not such a simple solution. I will
check if gruping works tomorow. Also, do You mean, go group everything
except mesh just by pressing crtl+g?##- Please type your reply above this
line -##
I accidentally accepted Your suggestion as a solution, since it did not help. The model does not scale properly. Could You maybe download it and look it up
gautham.chandran47
I've looked into the file,
I'm sharing the exact steps I did with your file,
• Deleted non-deformer history from the mesh,
• Grouped the joint hierarchy and used it as a scale option.
I've attached the file with my edits,
You can just connect that "group1" to a controller if you like.
https://drive.google.com/open?id=1sXHudpw47HXM1wIko-Pq2fdsU1MHAHmN
Happy rigging Smiley Happy
Please mark this as a solution if it helps you so others can find it easily.
Goutham Chandran
