Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Playback Cache losing blue line when changing current frame
Hi everyone, first time posting on the forum!
So I have a question for you all. My playback cache is setup and working pretty good I would say. Now question about it. everytime I'm changing the current frame in the timeline window the blue line disappear and the whole time range is being recalculated. Is there a reason why? It seems my teacher has it being calculated and stays there but he doesn't know what setting can cause that. I'm on a i9 and gpu is RTX 3070. Drivers are up to date, I'm using Maya 2020
kelly_hynes
That does not sound correct.  What does your scene contain?
Kelly
Kelly Hynes
Manager, Software QA Engineering
Installation & Licensing forums | Contact product support | Autodesk AREA
It contains 2 rigs (Apollo and Artemis) a piano model I took online for free. The scene kept crashing while saving on top of that. I did export the full scene as Maya ascii and it seems to have fix all the issues. Fingers crossed.
stephenkmann
Check your Cache playback settings.  You can set it to
  • forward and backward
  • forward
  • backward
  • forward from animation start
Most likely you have it set on the last one (fwd from animation start)
Your teacher should probably be aware of the cache playback preferences. So I'm assuming he already told you this. But maybe not.
hth
-=s
It is set to Forward and backward but thanks anyway. I'll have to do further research to find where the issue is coming from.
