Installing tweenMachine
import tweenMachine
tweenMachine.start()
# Error: ImportError: file <maya console> line 1: No module named tweenMachine #
i am trying to install tween machine and i believe im having a problem the directory system and maya not finding the file, i got tweenMachine working on a older computer but every time i try and get it to work on my new one i get this ImportError. i have hunted for every possible script directory variant but had no success and i am on my last wit. has any one run into this problem and found a solution. i am running maya 2019 and i believe im running the latest Tween version.
hamsterHamster
Should be located in your user profile Maya scripts folder https://github.com/boredstiff/tweenMachine/blob/master/README.md
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
  1. I have gone throught the readme files and found the right folder and it is not working I also tried ever other folder I could find. Bit when I run the script in Maya to active it I get the error that tween can't be found
dan97gaming
Community Visitor
Community Visitor
If you go to the python folder on tween machine you will find that the file name is Tween_machine.py, you should rename it to TweenMachine.py and then it will be alright
