how to make camera follow moving character without shake?
Hi. I'm a student learning basic animation.
recently I made run cycle and also made it moves forward.
I wanted to render the side view of it so I made character-camera parents ( checked only translate z) constrain.
and there's a problem that the character's 'translate z' is not a straight line as you can see below.
so the camera and the rendered video also rattled.
I searched other people's run cycle but mostly they didn't made the character actually moves forward.
just making a run cycle and render the side view of it so there's no any rattle.
I can do that, but I want to know how to make camera follow a character witch is actually moves forward.
Thank you for reading it 🙂
hamsterHamster
Assuming you have single-node camera (no Aim), for a straight run cycle you don't need constraints, overthinking. Simply, Z-snap camera to e.g. the root joint at the frame #1, set translate keys. Then go to the end of the intended animation and move Z-snap camera to the same joint again, set keys. In the GraphEditor ensure both key tangents are set to Linear.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
