Fbx export of animation from maya
Dear all,
i would be really happy if you could help me to export three animations from maya in fbx. There is a 60 second animation, it should be splitted into three 1-20 second, 21-40 second, and 41-60 second.
As a result I need to have an fbx file, which when loaded to FBX Review allows to swich between these three animations.
Thank you all in advance!
saihtam
Hey, as far as I know you can't do this via a nice UI in Maya unless you get a script/plugin from somewhere. But it is quite easy to do with code. You just need to tweak one simple line.
FBXExportSplitAnimationIntoTakes -v "nameOfTake" startFrame endFrame;
You just need to run that in your scene for each of your takes. I did a test of one FBX file with three takes and used this code.
FBXExportSplitAnimationIntoTakes -v "first" 1 10;
FBXExportSplitAnimationIntoTakes -v "second" 20 30;
FBXExportSplitAnimationIntoTakes -v "third" 40 50;
That gives me this:
https://gyazo.com/28761d30a97e76613e2f0c94cace0a96
You can also run this line to get the information about the takes you have created.
FBXExportSplitAnimationIntoTakes -q
Hope that helps. Let us know if you need any more help.
I found this information on this page which shows the different MEL commands for FBX.
- Mathias
Thank you so mush for your reply!
This works - thank you so much!!!
