Exporting animated sweep mesh
brian.bedwell6XFP4
brian.bedwell6XFP4
I've used the Sweep Mesh tool to create a mesh cable from a curve and I've animated the curve to have the mesh move around.
The only problem is I cannot export the mesh with the curve's animation.
HELP!!!!!
hamsterHamster
Export as what? Exporting within the Maya domain should automatically export all the nodes that are connected to the one in question.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
brian.bedwell6XFP4
I want to export to an FBX to be used in Unity.
hamsterHamster
Well, afaik, you rather want to export Alembic to Unity.
FBX won't support complex Maya node network.. if you can, convert your setup to a skinned/blendshaped mesh, then it will be exported.
,,,_°(O__O)°_,,,
brian.bedwell6XFP4
I was hoping I could just bake the animation to keyframes. 😞
Do you know how to convert to a skinned/blendshaped mesh?
hamsterHamster
I can't possibly guess what is in your scene, sorry.
I wouldn't cling to that FBX paradigm so much, better look into Alembic export, which IS supported by both Maya and Unity.
,,,_°(O__O)°_,,,
