Error: Geometry is not in a skinCluster
tanya1996rubchuk
Message 1 of 10
tanya1996rubchuk
Hello!
I’m new in rigging and skinning and that is just my first attempt to create a rig, so… I’ve got that error while trying to mirror weight I have painted for one side. Selected the mesh, applied mirror skin and got
“ Error: file: E:/ProgramFiles/Maya/Maya2022/scripts/others/doMirrorSkinWeightsArgList.mel line 84: Geometry is not in a skinCluster. “
Before doing rig, I have checked the model for symmetry and cleaned it (remove construction history, un-used nodes etc.), using Advanced Skeleton
Can’t to find any decision.. Anyone have some ideas what it can be?
Replies (9)
Message 2 of 10
Kahylan
Hi!
This Error normally shows up when you try to mirror skinweights on an unbound mesh.
Does your mesh follow the joints when you move them?
Are you sure that you have selected the Mesh direclty and not the Group above it?
Also sometimes rigs have more than one geometric part, for example separate eyes or eyelashes, could it be that you have one of those meshes not skinned yet but have it accidentally selected when trying to mirror skin weights?
Before mirroring skin weights, make sure you select your skinned mesh, and ONLY your skinned mesh.
I hope this helps!
Message 3 of 10
tanya1996rubchuk
Thank! I haven't skinned eyes yet, that are separated. Think it can be the
reason! Will continue that way.
Thank you!
Message 4 of 10
nethornhill
Community Visitor
Community Visitor
so helpful. 🙏 😊
Message 5 of 10
KUmarDIvesh
Observer
Observer
I am facing the same problem but i have skinned all the joints and also my characters meshes are different so what can i do about it i really need help on that
Message 6 of 10
Kahylan
can you explain what you mean by "all my characters meshes are different" ?
Do you maybe have some screenshots?
Message 7 of 10
KUmarDIvesh
Observer
Observer
I am Trying yo Mirror this mesh weight to another mesh menaing character right leg weight to character left leg @Kahylan
Message 8 of 10
Kahylan
Ok, for that to work both of your legs (the actual meshes not the group above them) need to be selected when you mirror the weights over. And both of your legs need to have a skincluster attached, then this should not be a problem. The settings depend on your naming conventions and positional precision.
Message 9 of 10
KUmarDIvesh
Observer
Observer
how to do skincluster its showing that error @Kahylan
Message 10 of 10
Kahylan
Well, the skincluster is the deformer tha gets created when you skin your mesh. Since you said that both legs are skinned, the should have skinclusters.
If you still have this error, it would probably be easiest if you attach your file so I can directly look at it and tell you how to fix it.
