Drive and keys problems
 Hello there,
I'am making a blocking for my short movie, and i'm encountering a curious problem... I'll try to explain you.
So i have a model, a little guy who have some blendshapes expressions. When he has the expression scared, his mouth is quite open, but his bottom teeth does not follow, so i've done a drive and key. Now, when he is scared, his teeth are following the jaw correctly, and i can also opened it further.
Everything is working fine with it... Except in the blocking scene. My blocking scene have 4 imported reference whose my little guy.
I have animated him, but suddenly the bottom teeth are moving when a expression is activated. They are moving accross his face, that's crazy. I mean, my little guy is so much scared that he looses his teeth! I don't know why. In the scene reference, everything works fine, but in the blocking scene there's is this mistakes.
I try to put the same keyframes in my guy's reference, and the teeth works fine. I also tried to put some limit in the attributs. Useless.
And can't even correct their position and put some keys on the teeth 'cause they are driven already...
Anyone have an idea ?
Have a good day.
ray
Can you post the file ?
