Copy Keys from blendshape and Paste on different Mesh?
JamesJ3D
JamesJ3D
Is it possible to copy the blendshape keys from a blendshape on one mesh and paste it on a different mesh with different geo?
I tried in the graph editor but no dice.
I'm only interested in the timings of the keys.
Thanks.
(Maya 2018)
stephenkmann
If the names of your blendShape channels are the same . you can copy and paste from the graph editor.
open the one with animation. in the GE and select all the channels in the editors outliner.
 copy
select the other blend shape
 paste
if the names are different, you can use the node editor to connect the output of each animation node to the channel of each blendShape channel.
 if you graph the inputs of the keyed blendShape you will see the animation nodes. and how they are connected.
 you can then connect them to your new blendShape instead.
hth
-=s
JamesJ3D
 copy
 paste
hth
-=s
Brilliant!! Worked like a charm!
Thank you so much!
