Can Interactive Playback record as keyframes?
litote
litote
Is Interactive Playback just for previs purposes, or is it possible to make it record the animation from it, e.g. for moving an nCloth flag about manually and recording the animation as cache or an object's translation movement as keyframes?
I am using Maya 2017.
mspeer
Hi!
Interactive Playback is just for playback there are no recording options.
litote
Thanks for your reply. I suspected as much.
tdHendrix
Hi, you can use the MEL command recordAttr to maybe do what you want. You find more info from this thread:
https://forums.autodesk.com/t5/maya-animation-and-rigging/is-it-possible-to-record-live-animation-da...
Greg Hendrix - Senior Technical Animator
LinkedIn : Twitter
