Blendshapes in the Time Editor
pixerati
Message 1 of 57
pixerati
I'm trying to edit a facial animation that has both bones and blendshape animation and I want to use the NLE features of the timeline to cut sections of mocap out and blend together.
Am I missing something, or is there no way to get blendshape animation into a track on the Time Editor timeline? If not, it seems like an odd omission. I can write a script to feed the animation into dummy bones and then put them in the timeline, but that's a whole lot of work and a bit of crazy for something that should be a default function.
Someone please tell me I'm just missing something obvious...?
Replies (56)
Message 2 of 57
francesco.torchia
Hi @pixerati,
in order to have the keys on the blend shape node displayed in the timeline, you need to have the blend shape node selected by clicking Select in the Blend Shape window.
Francesco Torchia
Technical Support Specialist – M&E (3ds Max, Maya)
Message 3 of 57
pixerati
OK, Great-I'll give that a try. Not very acquainted with the new Blend Shape editor; is there a way to select more than one blend shape at a time?
Message 4 of 57
francesco.torchia
Hi @pixerati,
These are the steps to select multiple nodes:
  • Highlight the first node in the Shape Editor window with a left click of the mouse
  • Highlight any other node with Ctrl+left click
  • Right click on one of the highlighted nodes and select Select Blend Shape Node
I've created also a short screencast.
91972941-7f37-4c4c-8dbc-b9eb44b5ca68
Francesco Torchia
Message 5 of 57
pixerati
Sorry-should have clarified. Is there a way to set all the shapes to Edit mode? Seems like you can only set one to edit at a time which would make for a very tedious transfer to the Time Editor if you have a lot of animated blend shapes...
Message 6 of 57
stephenkmann
edit is for editing the shape using sculpt brushes or similar.
 to affect the keyframes, just select the blendShape node.
you can also select it from by selecting your base geo( the one being deformed)  and then selecting the blendShape node from the channel box, or attribute editor.
hth
Message 7 of 57
pixerati
OK, that makes sense. But then I guess back to my original question: How do you get those shapes animations to show up as track clips in the Time Editor? No matter what I do they don't transfer into the Time Editor...?
Message 8 of 57
stephenkmann
open the time editor
the second button is for "create clip from selected"
press that button .
you should then see a clip show up in the time editor
hth
Message 9 of 57
pixerati
Not working here. Can I send you a sample file?
Steps to reproduce:
1. In the Shape editor, right-click the shape and choose, "Select blend shapes node". Keys then appear in timeline
2. Do one of the following: a) Click Add selected content from scene, b) Click the Create Clip from selection button, or c) Choose File>Add Animation from scene selection
3. The screen then flashes, "anim_Clip1_AnimSource has been created as an Animation Source"--see image below--but nothing is created in the Time Editor. I even tried creating a track ready to receive the clip, but it makes no difference.CreateAnimationClipInTimeEditor.png
Message 10 of 57
pixerati
OK, so the reason the clip didn't appear in the timeline was because "Create Animation Source only" was checked (not sure it this is the default)
Nevertheless, I still don't see the blend shape data transferred to the time editor.
Message 11 of 57
francesco.torchia
Hi @pixerati,
sorry for have kept you waiting for so long. We investigated some more and I would like you to try something on a simple test scene.
  1. Create a sphere
  2. Open the shape editor
  3. With the sphere selected, click Create Bland Shape
  4. Click Create Target
  5. Grab some verts and move them and make some animation with the blend shape, adding 2 or 3 keys
  6. Windows > animation editors > time editor
  7. In the shape editor, highlight the target node (in this case its pSphere1)
  8. In the Time Editor click “Add Selected Content”
When I did it, a track was created and it displayed the keys. Please let me know what happens when you follow the steps.
Francesco Torchia
Message 12 of 57
I am having a similar problem. When using Maya 2017, I could create a working animation clip by selecting blendshape node. Now with the 2018.3 time editor creates blendshape clip but the animation is gone. Scrubbing timeline has no effect. No matter what I tried, I couldn't find a solution 😞
Message 13 of 57
pixerati
It might be more helpful if I sent you a sample file...I'd rather see it working with real-world facial blendshape animation...but I will try it out.
Message 14 of 57
pixerati
OK, so I followed your exact steps and I get the error, "Nothing is selected."
If I select the pSphere in the Outliner in addition to the target in the Shape editor I do get an animation track created, but it doesn't transfer the keyframe data (even if I select the option to "Move animation to Time Editor from scene"). This is clear from the fact that I can shift the clip in the Time Editor and it doesn't affect the timing of the keyframes.
I'm using 2018.3
Message 15 of 57
Thank you for quick reply. I suppose this is a bug in 2018. I create the blendshape then select the "blendShape1" input from the channel box. This way I am able to create clip and can do everything in time editor. The problem is I am loosing blendshape animation. The object shape stays static and reflects the frame of animation at the moment of clip creation.  With Maya 2017, this process seems flawless.
Message 16 of 57
francesco.torchia
Hi @pixerati and @Anonymous,
would it be possible to send me a screencast showing what you exactly do, so that I can reproduce it locally and, possibly, create a ticket?
Francesco Torchia
Message 17 of 57
Hello again. I attached a simple screencast to demonstrate the problem. As I pointed out earlier, this works flawlessly in 2017. I checked again today. Thanks..
https://knowledge.autodesk.com/community/screencast/7cbab551-d85e-46d4-91fa-a91a09233cb4
Message 18 of 57
pixerati
And here's mine attached.
Message 19 of 57
francesco.torchia
Thanks a lot to the both of you, @pixerati and @Anonymous!
Francesco Torchia
Message 20 of 57
mspeer
Hi!
I can confirm that selecting the blendshape node and adding this animation to Time Editor works in Maya 2017.4, but not in Maya 2018.3.
A clip will be created and the connections seem to be correct, but the keys will not be evaluated.
