Blendshapes in the Time Editor
pixerati
Message 1 of 57
pixerati
I'm trying to edit a facial animation that has both bones and blendshape animation and I want to use the NLE features of the timeline to cut sections of mocap out and blend together.
Am I missing something, or is there no way to get blendshape animation into a track on the Time Editor timeline? If not, it seems like an odd omission. I can write a script to feed the animation into dummy bones and then put them in the timeline, but that's a whole lot of work and a bit of crazy for something that should be a default function.
Someone please tell me I'm just missing something obvious...?
Replies (56)
Message 41 of 57
Is there anyone who tried 2020?
Message 42 of 57
stoicsense
blendshape dosen't work in maya2020 time editor.
This is written in  autodesk tutorial maya2020.
I gave up and started using traxeditor. very old editor..
Message 43 of 57
marcury
yes just posted this bug and its all morning im wondering are u serious?? then i come here and its 2 years........the great maya ......... in the new amazing time editor................ cant use the most old animation trick called blendshape.......... in 2 years from 2017 working thing , nobody tried to catch that coding line to solve this thing? then yes i try do all in trax editor , then i have the problem about time warp all scene that in the time editor was working fine and only blendshape problem ... trax editor works blendshape but not time warp only can use start and end keys so cant use....
Message 44 of 57
marcury
after whole day seeing node editor , i saw the problem is the interpolation node , the one that get the animation curves and plug them back again with the orange time editor filter...... i found some workaround , need other "normal" attribute to get the same animation values as blendshape , add attribute in whatever object and copy the blendshape curve there , then this curve will work in the time editor , just need in the node editor , plug the output of this attribute animation to the input of blendshape weight object name....... at least in this way can save the scene , maybe maya 2025 will be fixed
Message 45 of 57
mikefoy1570
Any resolution yet to this issue?
Message 46 of 57
BenediZ
@mikefoy1570 There was a workaround mentioned before here in the thread:
You set an custom attribute for a locator or a group or whatever object. This is only used as a controller for the blendshape attribute values.
This object will be accepted by the time editor.
Then you can connect each new created attribute with the connection editor to the blendshape attribute.
A bit tedious, you have to set it up for each single blendshape, but so it's possible to get them all movable into the time editor.
Creating new attributes is possible in the channel box.
Message 47 of 57
onkelandy4815
Observer
Observer
Maya 2022 - still not working. Autodesk is just unreal.
Thanks alot for the workaround though, it works perfectly!!
Message 48 of 57
minas.aslanyan
Still can't modify blendshapes with time editor at the newest Maya 2023, any update or proper steps for fixing this will be highly appreciated.
Message 49 of 57
minas.aslanyan
Used Blender's NLA editor for this matter and it worked like a charm.
Message 50 of 57
RICCARDORUSSI9039
I installed 2023 and some buttons disappeared in the blend shape panel (key and visibility)
Let's hope for maya 2024 ... or maybe it's time to look further
Message 51 of 57
teddude75
Message 52 of 57
stoicsense
I cannot edit the animation while viewing the results. Very sad. Thanks for the video.
Message 53 of 57
BradClarkRiggingDojo
This is still a problem and bug in the Time Editor as of 2022-2024
Message 54 of 57
kelly_hynes
Hi all,
Note that this issue was recently fixed in our internal branches of Maya:
Maya-87241 :  TimeEditor : Blendshape animation clips are not working
Kelly
Kelly Hynes
Manager, Software QA Engineering
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 55 of 57
Message 56 of 57
stoicsense
I appreciate your efforts in addressing this issue. I'm looking forward to the release that includes this fix.
Message 57 of 57
stoicsense
I am deeply grateful for the implementation of the long-awaited blend shape editing feature in the Time Editor with the latest update of Maya. This functionality will greatly assist us creators, expanding the possibilities of our creativity. I express my profound respect for your dedicated efforts.
