公告
A huge problem with adding IK controls for my character rig
不适用
2,881 次查看
12 条回复
1 条消息(共 13 条)
不适用
I have finished creating a rig and skin for my character, and when I added an IK control for the leg, it just messes up the model and the skeleton when trying to move the leg. Here's the IK in it's normal position:
y6sqjal6RBqFbBsOwSSIjQ
and here's the IK when moving it:
Uk2oQ8VgSE_sjHnzjBQ0sg
I have no idea why it's happening or how to fix it, I also attached the maya file and the model file so you can check it for yourself (There is no IK in that file, I deleted it)
Thanks!
0 个赞
已接受的解答 (2)
2,882 次查看
12 条回复
回复 (12)
2 条消息(共 13 条)
mspeer
Hi!
You should not ad IK controls to full or almost straight and unrotated joints.
0 个赞
3 条消息(共 13 条)
不适用
Thanks for the reply.
Then what should I add instead? I want to add something that will help me animating the character easier - I can't just leave it like that.
That's right -  I did not rotate any of the Joints, I only placed them. Do I have to re-create the rig and rotate them instead of placing them, or can be alternative soultion?
0 个赞
4 条消息(共 13 条)
mspeer
Hi!
Just for a test slightly rotate some of the joints (in the wanted direction) and add the IK handle again to see the difference.
0 个赞
5 条消息(共 13 条)
不适用
And in order to do that I need to orient the joint’s local axes manually?
0 个赞
6 条消息(共 13 条)
mspeer
Hi!
Yes.
0 个赞
7 条消息(共 13 条)
不适用
Tried it, it did not work
 In fact, it did not change a thing.
0 个赞
8 条消息(共 13 条)
mspeer
已接受的解答
Hi!
After changing the rotations and before applying the IK Handle you need to "Set Preferred Angle" (set starting pose) for the skeleton, then it works:
0 个赞
9 条消息(共 13 条)
不适用
h, I see. Thank you very much!
0 个赞
10 条消息(共 13 条)
不适用
A question:
In what direction and what joints did you actually rotate?
0 个赞
11 条消息(共 13 条)
mspeer
Hi!
Just watch the animated GIF, it clearly shows the difference between left and right leg.
0 个赞
12 条消息(共 13 条)
不适用
I can't really see the difference to be honest. But what I ask is how to get that difference.
What joints did you rotate? To what directions? Which way the X, Y and Z axies are facing? If you can tell me what you exactly did and how, you will literally save me.
I tried to rotate the joints myself, but never got the wanted results
0 个赞
13 条消息(共 13 条)
mspeer
已接受的解答
Hi!
If you still can't see the difference between the right leg (straight) and left leg (curved), then i can't help you further.
Just rotate the individual joints manual.
Read more about Rigging and Animation in the Maya Online Help / Documentation and anywhere else.
0 个赞
