A huge problem with adding IK controls for my character rig
Message 1 of 13
I have finished creating a rig and skin for my character, and when I added an IK control for the leg, it just messes up the model and the skeleton when trying to move the leg. Here's the IK in it's normal position:
y6sqjal6RBqFbBsOwSSIjQ
and here's the IK when moving it:
Uk2oQ8VgSE_sjHnzjBQ0sg
I have no idea why it's happening or how to fix it, I also attached the maya file and the model file so you can check it for yourself (There is no IK in that file, I deleted it)
Thanks!
Replies (12)
Message 2 of 13
mspeer
Hi!
You should not ad IK controls to full or almost straight and unrotated joints.
Message 3 of 13
Thanks for the reply.
Then what should I add instead? I want to add something that will help me animating the character easier - I can't just leave it like that.
That's right -  I did not rotate any of the Joints, I only placed them. Do I have to re-create the rig and rotate them instead of placing them, or can be alternative soultion?
Message 4 of 13
mspeer
Hi!
Just for a test slightly rotate some of the joints (in the wanted direction) and add the IK handle again to see the difference.
Message 5 of 13
And in order to do that I need to orient the joint’s local axes manually?
Message 6 of 13
mspeer
Hi!
Yes.
Message 7 of 13
Tried it, it did not work
 In fact, it did not change a thing.
Message 8 of 13
mspeer
Hi!
After changing the rotations and before applying the IK Handle you need to "Set Preferred Angle" (set starting pose) for the skeleton, then it works:
Message 9 of 13
h, I see. Thank you very much!
Message 10 of 13
A question:
In what direction and what joints did you actually rotate?
Message 11 of 13
mspeer
Hi!
Just watch the animated GIF, it clearly shows the difference between left and right leg.
Message 12 of 13
I can't really see the difference to be honest. But what I ask is how to get that difference.
What joints did you rotate? To what directions? Which way the X, Y and Z axies are facing? If you can tell me what you exactly did and how, you will literally save me.
I tried to rotate the joints myself, but never got the wanted results
Message 13 of 13
mspeer
Hi!
If you still can't see the difference between the right leg (straight) and left leg (curved), then i can't help you further.
Just rotate the individual joints manual.
Read more about Rigging and Animation in the Maya Online Help / Documentation and anywhere else.
