Lighting Analysis Results Trouble
mpowell_arch
Message 1 of 9
mpowell_arch
I have been running daylight analysis multiple time with success on this model, but recently I noticed it has an error and I run a new analysis, and it appears to show in my online gallery, and then I get an email when complete, but it never shows on the list when I go to load it back in and display it in the model. Are these errors related? what is going on?
Matt
After running new analysisAfter running new analysisdetails of following errordetails of following error
Replies (8)
Message 2 of 9
scheerd
Likely those are related.  What is your exact process for recreating this error?
David
Message 3 of 9
mpowell_arch
This is the results of analysis.
You might be interested in this Screencast:
INsight360 not saving daylight results after sync and close and re-open.
https://forums.autodesk.com/t5/lighting-solar-analysis-forum/lighting-analysis-results-trouble/m-p/8...
https://autode.sk/2U1SDce
Capture and Share Your Expertise
Autodesk Screencast lets you capture your workflows to easily create powerful and
engaging learning materials. For more information visit:
https://screencast.autodesk.com/
Message 4 of 9
mpowell_arch
Message 5 of 9
mpowell_arch
Message 6 of 9
mpowell_arch
This error popped up again. I think it was after a revit crash when I I had a recent analysis loaded. now it appears that the command is left incomplete.
Message 7 of 9
mpowell_arch
How do I clear a transaction error?
Message 8 of 9
scheerd
A transaction error is some problem with the addin.
Can you send the log files from <mydocs>/Autodesk/RevitDaylighting to [email protected]?
Also the html error report you saved.
Also be sure you're using the latest version of the addin (v4.01) from https://insight360.autodesk.com/oneenergy/Landing/Download
Thx
David
Message 9 of 9
scheerd
Important notes about changes to handling of glazing materials for Insight Lighting v4+ are available at the post below:
https://forums.autodesk.com/t5/lighting-solar-analysis-forum/critical-update-glazing-materials-for-l...
Insight version 4.031 is available here:
When updating to this new version, be sure to check your Glazing materials per the post above
