Daylight in rooms that should not have daylight
pete3RG7H
Observer Observer
pete3RG7H
Observer
Observer
I have been working on a Revit project that is going for LEED recognition, and have been doing 'test' lighting analysis for the 2nd floor space as it allows me to do the whole floor on low resolution for 0 credits. The problem is that I am getting footcandle readings in rooms that have no windows (interior or exterior.) These will not show up when I do the final version, as they are not regularly occupied spaces, but it does make me question the validity of the other spaces.
See image and please help!!
Thanks.
pete3RG7H
Observer
Observer
values also seem high in the other rooms included
scheerd
Hello.
Here are some things you might check.  You can also send the model to us at LAR.Feedback@autodesk.com if you'd like me to take a look.
1. Glazing materials RGB TVis is not defined properly.  Use Glazing or Glass materials, remember that window pane modeled thickness matters, and the RGB values on the Appearance tab are the important ones for Rendering and LAR.
http://help.autodesk.com/view/BUILDING_PERFORMANCE_ANALYSIS/ENU/?guid=GUID-1038E22F-2EF1-46E0-AAF8-D...
2. Opaque materials (wall, ceiling, etc) may have 'self-illuminance' modifier defined in the Appearance properties.  I've seen this a lot when the visual rendering people set artificial characteristics to make the renderings look good, but not 'real'.
3. The '_Lighting Analysis Model View'; which is the view used for the analysis, may have some objects hidden that allow daylight into the rooms.  Maybe a wall, or a missing floor or ceiling above, etc.
4. The '_Lighting Analysis Model View' has a section box cutting a wall open, which will be reflected in the analysis model.  This is usually automatically removed for analysis, but there is a 'Settings' option (gear icon on the LAR analysis dialog) to override the section box that may be unchecked.
5. Electric lights are defined in the space and are turned on in the '_Lighting Analysis Model View'.  These are usually automatically turned off, but there is a 'Settings' option to override artificial lights that may be unchecked.
I'd be glad to hav ea look if you want to send me the model.
David
kevin
The model is too large to send via email. I have partially figured out the daylighting issue (I had missed a step in setting up the sun location via the rendering settings), but am now having an issue with not all of the daylighting values showing up in the plans even though it is listed in the schedule. It shows up in my 3d View, but am sending PDF plans to LEED.
