Revit Dynamo Solar Analysys
johan.cantryn
Message 1 of 9
johan.cantryn
It seems that the Solar analysis nodes in Dynamo expired on jan 1st.
When they will be available again? What, in general, are you planning with the combination Dynamo and Analysis?
Johan
Replies (8)
Message 2 of 9
scheerd
Hi Johan
Yes it looks like you're right.  I guess we missed that internal communication, and I hadn't caught it yet in my work.  We definitely want to keep the solar nodes out there and in use, so I'll ask the team to update the expiration and get that posted asap.
Meanwhile, our intentions with BPA in Dynamo are to continue the path of Dynamo-izing BPA functionality for internal and community prototyping using the same engines as we use in Insight360 analysis tools.  Once we get you the updated DLL for solar, I'd love to hear more about what you are doing or want to do with analydid tools in Dynamo, as input like yours helps support internal planning a prioritization.
Thanks for the notice,
David
Message 3 of 9
kesimmon
Hi it looks like this has expired again on November 31 2016. Can you please renew it? We are in the middle of a research grant and need it to complete in March. Please let me know what the intention is for this long term.
Message 4 of 9
krishnan.gowri
We are working on an update for the 2016 Plugin and it should be available soon.  In the meantime, you may want to update to Revit 2017.1 and the new plugin for that is working without any limitations and has some additional new features.
Krishnan Gowri, Ph.D. FASHRAE, LEED AP
Principal Engineer
Generative Design Group
Message 5 of 9
mstein7484
We just now posted a new version of the plugin available which will resolve the problem with Revit 2016 Solar Analysis. Insight Plugin Downloads
Let us know if you have more questions on this topic, otherwise please accept as a solution so that others can benefit from this information.
Marjorie Stein
QA Analyst
Autodesk, Inc.
insight.support@autodesk.com
Message 6 of 9
kesimmon
Sorry for the miss communication what I need is an updated Dynamo package for "Solar analysis for Dynamo" last published by "DynamoTeam" package version 0.9.2. this Dynamo package states it will time out on Jan 1st 2016, as it did.
Thank you,
Adam Simmons | Associate
SE Regional BIM Manager
202.263.5439 Direct
Gensler
2020 K Street NW
Suite 200
Washington DC 20006
*I check e-mail at 7am and 4pm and will respond at those times. If you have an urgent matter please call or message.
Message 7 of 9
johan.cantryn
@kesimmon
A newer version is available but with another package name. Look for the SolarTestTrident package.
Johan
Message 8 of 9
kesimmon
I am again having issues this time with the dynamo package Solar test trident. The weather nodes in the package dont seem to be able to get the weather form the weather server and errors with the following below.
Any help you can provide ASAP, workaround or otherwise, would be greatly appreciated as this halts the work we are doing.
Message 9 of 9
johan.cantryn
@kesimmon
The Solar Test Trident was just a temporary package. The latest version of the solar analysis was published afterwards with the name Solar Analysis for Dynamo. I also published this on y blog: https://bimnature.wordpress.com/2017/01/20/new-version-for-the-solar-analysis-dynamo-package/
With the test trident package I also had problems with the weather data, but not anymore with the "final" package.
