Write external ilogic folder paths through VBA
danny.lewisA9QBW
danny.lewisA9QBW
I'm obviously doing something wrong... but can't for the life of me figure out what (Not super VBA savvy).
'preamble in VBA
    Dim ClientId As String
    ClientId = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}"
    Dim iLogicAddIn As ApplicationAddIn
    Set iLogicAddIn = ThisApplication.ApplicationAddIns.ItemById(ClientId)
    Dim iLogicAuto As Object
    Set iLogicAuto = iLogicAddIn.Automation
    If (iLogicAuto Is Nothing) Then
        Call MsgBox("Can not use iLogic")
        Exit Sub
'Works in iLogic
'''Dim iLogicAuto = iLogicVb.Automation
'''Dim ilogicPath As String() = {"C:\Vault\Testing\", "C:\Vault\Testing2\"}
'''iLogicAuto.FileOptions.ExternalRuleDirectories = ilogicPath
'Doesn't work in VBA
ilogicPath = Array("C:\Vault\Testing\", "C:\Vault\Testing2\")
Let iLogicAuto.FileOptions.ExternalRuleDirectories = ilogicPath
Relevant:
https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=a6d2fdcb-7753-9394-07c4-adb50a85b9e8
Ralf_Krieg
Hello
Try
'preamble in VBA
        Exit Sub
'Works in iLogic
Dim ilogicPath() As String
ilogicPath() = Split("C:\Vault\Testing\,C:\Vault\Testing2\", ",")
R. Krieg
RKW Solutions
www.rkw-solutions.com
danny.lewisA9QBW
@Ralf_Krieg  Thank you sir!
danny.lewisA9QBW
For anyone else trying to do this; if you want it to just be a single path for the external iLogic folders, here's the code:
ilogicPath() = Split("Your Path Here", ",")
bradeneuropeArthur
How can I return the path locations?
msgbox (iLogicAuto.FileOptions.ExternalRuleDirectories.item(1))....
for example
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
danny.lewisA9QBW
The 'ExternalRuleDirectories' is stored as a 1-dimensional array.
You could probably create a quick function that would look for the comma (,) and then parse it into an array that's returned. The quick snip below puts it into a regular string that you can just manipulate or you can try and deal with the array as it is.
Dim output As String = String.Join(", ", iLogicAuto.FileOptions.ExternalRuleDirectories)
Logger.Info(output)
