Woodworking for inventor commands ilogic
simonford026
simonford026
Can anyone tell me how to write a I logic code to perform the refresh material in woodworking for inventor.
  1. Alternatively is it possible to find and add commands into ilogic image001.png
bradeneuropeArthur
Can you run the code from the help file (programming help) that exports all commands to a txt file and send me the result. After i have that i can help you further.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
A.Acheson
To work with inventor commands here is two rules to retrieve commands and then execute. It may not be able to retrieve the Woodworking addin commands but try it anyhow. I know it can retrieve the T&P Addin commands. From the API Help here is the ControlDefinition Object
Get Commands List
' Get the CommandManager object.
Dim oCommandMgr As CommandManager  = ThisApplication.CommandManager
' Get the collection of control definitions.
Dim oControlDefs As ControlDefinitions = oCommandMgr.ControlDefinitions
oWrite = System.IO.File.CreateText("C:\Temp\CommandNames.txt")'Create and write to a text file
For Each oControlDef In oControlDefs ' iterate through the commands and write to file
	oWrite.WriteLine(oControlDef.InternalName & "                        " & oControlDef.DescriptionText)
Next
oWrite.Close() ' Close the temp file
ThisDoc.Launch("C:\Temp\CommandNames.txt")'open the file
Execute
' Get the control definition for the Place Component command.
	Dim ctrlDef As Inventor.ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("TP:Fitting:Delete")
	'Enable in the ribbon (if necessary)
	'ctrlDef.Enabled = True
	' Execute the command.
	ctrlDef.Execute
Regards
Alan
