Viewing problem part
Message 1 of 23
Hi all,
I'm working on Inventor and since a week I get some viewing problem of my parts (picture below), it's mainly appear when I zoom in / zoom out and it disapear when I reopen the file.
Does someone already had this problem and know how to solve it?
For information all the update for the graphic card are done.
Thanks forward and best regards,
Benjamin
Replies (22)
Message 2 of 23
bradeneuropeArthur
What version of inventor are you using?
What system are you using?
What are your application settings for hardware?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 23
I'm on Inventor Professional 2012
Windows 7 64bits
Intel core i7-4800MQ
RAM 8GO
AMD Radeon HD 8790M / Intel HD graphics 4600
Message 4 of 23
bradeneuropeArthur
Could you please make an export of your "Application Options" and upload it?
Otherwise this will maybe help to solve the problem:
https://forums.autodesk.com/t5/simulation-mechanical-forums/display-grafic-problem-model-turns-after...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 23
Enclosed the Application options file
Message 6 of 23
bradeneuropeArthur
Nothing enclosed.....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 23
2nd try
Message 8 of 23
bradeneuropeArthur
Nothing....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 23
Maybe my firewall block it
Is it ok if I send you the text below :
Message 10 of 23
bradeneuropeArthur
no text....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 23
bradeneuropeArthur
otherwise make a screenshot of your hardware tab!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 23
The screenshot
Message 13 of 23
bradeneuropeArthur
No Screenshot....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 23
Option application
Message 15 of 23
bradeneuropeArthur
These are correct.
Could you please run "Diagnostics" in the hardware tab, and show what the message is?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 23
the diagnostic
Message 17 of 23
bradeneuropeArthur
As you can see the internal graphic driver is used.
This means the AMD graphic driver is not used.
Check this:
Check if there is something wrong here....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 18 of 23
Yes I just seen that, do you know where I can switch to the AMD card ?
Message 19 of 23
bradeneuropeArthur
go to "My Computer" >> Manage >>Device manager >> Display Adapters
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 20 of 23
bradeneuropeArthur
otherwise:
You should go to your AMD graphics card control panel and force the Autodesk Simulation app to use AMD graphics card.. You may need administrative priveleges on your computer in order for Simulation to accept this change
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
