VBA Forms - how do I distribute?
sam
sam
Hi Everyone,
With help of this wonderful community I have been able to learn a lot in last couple of months, though still a long way to go.
I have created a VBA that creates custom parts as per given selections and inputs of button and then it assembles them in an assembly and later it creates drawing for each part. I have read various posts (& AU classes) on subject of VBA and Add-ins and I understand that distribution of VBA is not easy. My question is, whether is there any possibility to run this form through button on tool bar or may be through a Macro?
Any reply or reference to help material will really be appreciated.
PS. I am trying hard to get Visual Studio installed but it definitely take long to get a reply for that.
Best regards,
sam
Accepted solutions (3)
Replies (12)
bradeneuropeArthur
Can you store your VBA project on shared network drive?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
sam
@bradeneuropeArthur Yes, I guess that could be done. How would that help?
bradeneuropeArthur
Because all users use the same project within inventor then.
If you change something, this will be available directly to all users!
Arthur Knoors
sam
@bradeneuropeArthur Thanks for that - that I guess will solve the problem partly. Any suggestion/help for this part in my OP.
Best regards,
sam
bradeneuropeArthur
Please ask what you need and i will guide you through...
Arthur Knoors
bradeneuropeArthur
You can add macro-buttons yes!
Arthur Knoors
sam
Sure - Lets suppose that everyone has access to the project through shared drive as suggested by you.
Now - whenever I need to access this form I to VBA Editor and press (F5) Run UserForm to see the form. Is there any way that a user could shoot this off from an icon on tool bar (or anything  else to avoid opening VBA editor)
best regards,
sam
sam
@bradeneuropeArthur Thanks. Please consider that I don't know really much (though I have foolishly claimed in OP that I have learned a lot).. So you mean I can call this form through macro and macro can be activated through a button on tool bar? Would you mind elaborating this in little detail (whenever possible for you).
best regards,
sam
bradeneuropeArthur
you need to add a bitmap with the same name as the module to the folder with the vba modules.
keep reading for details
Arthur Knoors
bradeneuropeArthur
like this:
https://forums.autodesk.com/t5/inventor-customization/no-customicon-to-vba-macro-button/td-p/9061649
Arthur Knoors
bradeneuropeArthur
use a single module to show your form, like:
You can now add this module to the ribbon of inventor:
Hope this explains.
Arthur Knoors
sam
@bradeneuropeArthur Thank you so much for patiently explaining this to me. I will keep on digging more resources (and links you provided).
best regards,
sam
