vba does not work in inventor 2020
rickER9UF
rickER9UF
i have the below code with a button that exports a drawing to dwf in one click, works great in 2014 however just got 2020 and the program is catching in the red text line.........any ideas would be great as this command is quick and handy, thank you
Sub dwfmaker()
MsgBox "DWF-filer creating", vbInformation
Dim invApp As Inventor.Application
Set invApp = ThisApplication
' invApp.SilentOperation = True
Dim idwDoc As Inventor.DrawingDocument
Set idwDoc = invApp.ActiveDocument
Dim dwfFile As String
Dim laserdir As String
Dim FirstLet As Variant
Dim Output As Integer
Dim MyCheck As String
FirstLet = Left(idwDoc.DisplayName, 1)
MyCheck = IsNumeric(FirstLet)
If MyCheck = True Then
laserdir = "x:\" + "Numbered" + "\"
Else
laserdir = "x:\" + FirstLet + "\"
End If
dwfFile = laserdir + idwDoc.DisplayName + ".dwf"
'determine of dwf already exists
Dim FilePath As String
FilePath = ""
FilePath = Dir(dwfFile)
If FilePath = "" Then
'MsgBox "File doesn't exist"
Output = MsgBox("File Doesn't Exist", vbOKCancel)
'If Output = 1 Then
With invApp.CommandManager
Call .PostPrivateEvent(kFileNameEvent, dwfFile)
Call .StartCommand(kFileSaveCopyAsCommand)
End With
Set idwDoc = Nothing
Else
Output = MsgBox("File Exists", vbOKCancel)
Output = 2
End If
If Output = 2 Then
Output = MsgBox("Do You Want To Overwrite Existing File?", vbYesNoCancel)
End If
If Output = 6 Then
End With
ElseIf Output = 7 Then
Else
Output = 2
End If
End Sub
Rene_Gerlach
From Inv2009(!) documentation:
Note 2. The CommandManager.StartCommand (commandID) method to launch in Inventor command has been depreciated. Please use the ControlDefinition.Execute method instead.
WCrihfield
See if this edit works for you instead:
(I replaced your 'With' blocks with a simple SaveAs() method.)
Sub dwfmaker()
    Else
    End If
    FilePath = ""
        Call idwDoc.SaveAs(dwfFile, True) 'True = SaveCopyAs
    Else
        Output = 2
    End If
    If Output = 2 Then
    End If
    If Output = 6 Then
    Else
        Output = 2
    End If
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click 'LIKE' :thumbs_up:.
If you have time, please... Vote For My IDEAS :light_bulb:and Explore My CONTRIBUTIONS
Inventor 2021 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
(Not an Autodesk Employee)
Rene_Gerlach
Just a comment:
Please never ever use the DisplayName for the filename! The DisplayName can contain characters that are not allowed for filenames, like "/\<:|".
Try instead:
Dim fso As New Scripting.FileSystemObject
dwfFile = laserdir + fso.GetBaseName(idwDoc.FullFileName) + ".dwf"
rickER9UF
Thank you Rene!! i appreciate the response
