I'm running into a strange issue where setting the Automated Centerlines in a VB.NET Inventor addin doesn't give the expected results. I tried digging around on these forums, but failed to find anybody else that mentioned this issue.
This is a snippet of the iLogic, and it does exactly what I want it to do.
Dim oBaseView As DrawingView
oBaseView = ThisApplication.ActiveDocument.Sheets(1).DrawingViews(1)
Dim oACS As AutomatedCenterlineSettings
oBaseView.GetAutomatedCenterlineSettings(oACS)
oACS.ApplytoHoles = True
oACS.ApplyToCircularPatterns = True
oBaseView.SetAutomatedCenterlineSettings(oACS)
The result of the iLogic:
Here is the code in VB.net.
'Does the automated centerlines command
g_inventorApplication.StatusBarText = "Adding additional centerlines..."
Dim centerlineSettings As AutomatedCenterlineSettings = FlangePlateDrawing.DrawingSettings.AutomatedCenterlineSettings
FlangePlateDrawingSheet.DrawingViews.Item(1).GetAutomatedCenterlineSettings(centerlineSettings) 'Get
centerlineSettings.ApplyToBends = False
centerlineSettings.ApplyToCylinders = False
centerlineSettings.ApplyToFillets = False
centerlineSettings.ApplyToPunches = False
centerlineSettings.ApplyToRectangularPatterns = False
centerlineSettings.ApplyToRevolutions = False
centerlineSettings.ApplyToSketches = False
centerlineSettings.ApplyToWorkFeatures = False
centerlineSettings.ApplyToCircularPatterns = True
centerlineSettings.ApplyToHoles = True
centerlineSettings.ProjectionNormalAxis = True
centerlineSettings.ProjectionParallelAxis = False
centerlineSettings.RadiusThresholdPrecision = 2
FlangePlateDrawingSheet.DrawingViews.Item(1).SetAutomatedCenterlineSettings(centerlineSettings) 'Set
and here is the result of that code:
I've tried several times, such as commenting out all of the centerlineSettings lines that are being set to false, adding a delay before the FlangePlateDrawingSheet.DrawingViews.Item(1).SetAutomatedCenterlineSettings(centerlineSettings) line, and not including the ProjectionNormalAxis or RadiusThresholdPrecision values to make the code only have the same properties being set as the iLogic. One interesting thing I discovered in my debugging attempts is that if it doesn't set ApplyToCircularPatterns equal to True, I get the crosshairs centerlines for all of the holes. This lead me to think maybe it's processing too fast and putting the crosshairs centerlines in before it realizes that all of the holes are in the circular pattern. I thought adding a delay might fix that, but it did not.
I'm using Visual Studio 2019 to develop an addin for Inventor 2019 (originally for Inventor 2016).
Does anybody know why this is happening and how to fix it?
I never found a way to get the automated centerlines to work, but I did find a workaround: manually add the centerlines. (Heavy inspired by: https://forums.autodesk.com/t5/inventor-customization/automated-centerline-orientation-for-holes-in-...)
In that link, @j.pavlicek mentioned the AddCenteredPattern subroutine. (I'll list below.) It does take some more code to pull it off, as you have to have a object collection for the bolt holes, but if you already have loops, select statements, and/or if statements to get object collections for arranging dimensions, it's not that much extra work.
Centerlines.AddCenteredPattern( PatternCenter As GeometryIntent, CenterEntities As ObjectCollection, [CentermarkStyle] As Variant, [Layer] As Variant, [Closed] As Boolean ) As Centerline
Name | Type | Description |
PatternCenter | GeometryIntent | Input GeometryIntent that defines the a circular or elliptical drawing curve that defines the center of the pattern. |
CenterEntities | ObjectCollection | Input ObjectCollection object that contains the set of entities that define the points the centerline passes through. Valid objects for input are GeometryIntent objects that reference circular or elliptical drawing curves, and center marks. |
CentermarkStyle | Variant | Object that specifies the center mark style to use for the centerline. If not specified, the style defined by the active standard is used. |
Layer | Variant | Object that specifies the layer to use for the centerline. If not specified, the layer defined by the active standard is used. |
Closed | Boolean | Input Boolean that indicates if the centerline should be closed or not. |
Here's the code I used, with the extra unrelated code for arranging dimensions stripped out.
Dim oBoltHoles As ObjectCollection
oBoltHoles = g_inventorApplication.TransientObjects.CreateObjectCollection
'Set reference to drawingCurves
Dim oDrawingCurve_OuterDiameter As DrawingCurve = Nothing
For i = 1 To FlangePlateDrawingSheet.DrawingViews.Item(1).DrawingCurves.Count
'Checks to see if the the curve has is a circle, and matches the drawing view center's location.
If Not (FlangePlateDrawingSheet.DrawingViews.Item(1).DrawingCurves.Item(i).CenterPoint Is Nothing) Then
If FlangePlateDrawingSheet.DrawingViews.Item(1).DrawingCurves.Item(i).CurveType = CurveTypeEnum.kCircleCurve AndAlso
FlangePlateDrawingSheet.DrawingViews.Item(1).DrawingCurves.Item(i).CenterPoint.X = FlangePlateDrawingSheet.DrawingViews.Item(1).Center.X And
FlangePlateDrawingSheet.DrawingViews.Item(1).DrawingCurves.Item(i).CenterPoint.Y = FlangePlateDrawingSheet.DrawingViews.Item(1).Center.Y Then
'Checks to see if the drawingCurve is the flange's outer diameter drawingCurve.
If oDrawingCurve_OuterDiameter Is Nothing Then
oDrawingCurve_OuterDiameter = FlangePlateDrawingSheet.DrawingViews.Item(1).DrawingCurves.Item(i)
ElseIf oDrawingCurve_OuterDiameter.ModelGeometry.Geometry.Radius < FlangePlateDrawingSheet.DrawingViews.Item(1).DrawingCurves.Item(i).ModelGeometry.Geometry.Radius Then
'If the radius is greater, than this drawingCurve replaces the previously found drawingCurve
End If
ElseIf FlangePlateDrawingSheet.DrawingViews.Item(1).DrawingCurves.Item(i).CurveType = CurveTypeEnum.kCircleCurve Then
oBoltHoles.Add(FlangePlateDrawingSheet.CreateGeometryIntent(FlangePlateDrawingSheet.DrawingViews.Item(1).DrawingCurves.Item(i)))
End If
End If
Next i
'Creates the Geomentry Intent for the OD, which will be used as the object to get the center for the centerline centered pattern.
Dim oGeometryIntent_OuterDiameter As GeometryIntent = FlangePlateDrawingSheet.CreateGeometryIntent(oDrawingCurve_OuterDiameter)
'Add Centerlines
Try
FlangePlateDrawingSheet.Centerlines.AddCenteredPattern(oGeometryIntent_OuterDiameter, oBoltHoles,,, True)
Catch ex As Exception
MsgBox("Failed to add centerlines to the drawing." & vbCrLf & "Please manually add the centerlines once the automation finishes. (Right click -> Automated Centerlines)", vbCritical, "Error")
End Try
One note:
Without the "true" parameter at the end of the AddCenteredPatterns, the centerline would go though all of the holes, but there would be a gap between two of them. Changing the value from the default (of false), to true, it closes the centerline and has a complete circle.
@dtimm8RCUMNice.
I took the liberty of edit your code for better readability and formatting.
Dim oBoltHoles As ObjectCollection oBoltHoles = g_inventorApplication.TransientObjects.CreateObjectCollection Dim DrwView As DrawingView = FlangePlateDrawingSheet.DrawingViews.Item(1) 'Set reference to drawingCurves Dim oDrawingCurve_OuterDiameter As DrawingCurve = Nothing For i = 1 To DrwView.DrawingCurves.Count Dim DrwCurve As DrawingCurve = DrwView.DrawingCurves.Item(i) 'Checks to see if the the curve has is a circle, and matches the drawing view center's location. If Not (DrwCurve.CenterPoint Is Nothing) Then If DrwCurve.CurveType = CurveTypeEnum.kCircleCurve AndAlso DrwCurve.CenterPoint.X = DrwView.Center.X And DrwCurve.CenterPoint.Y = DrwView.Center.Y Then 'Checks to see if the drawingCurve is the flange's outer diameter drawingCurve. If oDrawingCurve_OuterDiameter Is Nothing Then oDrawingCurve_OuterDiameter = DrwCurve ElseIf oDrawingCurve_OuterDiameter.ModelGeometry.Geometry.Radius < DrwCurve.ModelGeometry.Geometry.Radius Then 'If the radius is greater, than this drawingCurve replaces the previously found drawingCurve oDrawingCurve_OuterDiameter = DrwCurve End If ElseIf DrwCurve.CurveType = CurveTypeEnum.kCircleCurve Then oBoltHoles.Add(FlangePlateDrawingSheet.CreateGeometryIntent(DrwCurve)) End If End If Next i 'Creates the Geomentry Intent for the OD, which will be used as the object to get the center for the centerline centered pattern. Dim oGeometryIntent_OuterDiameter As GeometryIntent = FlangePlateDrawingSheet.CreateGeometryIntent(oDrawingCurve_OuterDiameter) 'Add Centerlines g_inventorApplication.StatusBarText = "Adding additional centerlines..." Try FlangePlateDrawingSheet.Centerlines.AddCenteredPattern(oGeometryIntent_OuterDiameter, oBoltHoles,,, True) Catch ex As Exception MsgBox("Failed to add centerlines to the drawing." & vbCrLf & "Please manually add the centerlines once the automation finishes. (Right click -> Automated Centerlines)", vbCritical, "Error") End Try
