I do a lot of right hand/left hand sheet metal parts that are currently driven by ilogic through a form, but when I switch from right hand to left hand it breaks all my drawings, because the flat pattern randomly changes orientation when I mirror a part, I can set up an oriention for the mirrored version and the regular version and then the drawings work fine and the dimensions reattach, but changing the flat pattern orientation requires opening the part, switching to flatpattern mode and editing the "flat pattern definition" and changing it manually there and hitting apply. There has to be a way to switch the named faltpattern oriention with ilogic. Any help would be appreciated.
Solved by JelteDeJong. Go to Solution.
hi you can edit the "flat pattern definition" by iLogic. Below an example for flipping the alignment axis.
Dim doc As PartDocument = ThisApplication.ActiveDocument Dim sheetMetalDef As SheetMetalComponentDefinition = doc.ComponentDefinition sheetMetalDef.FlatPattern.FlatPatternOrientations.ActiveFlatPatternOrientation.FlipAlignmentAxis = True
the "ActiveFlatPatternOrientation" has more methodes for editing the "flat pattern definition". you can find them in the help.
Jelte de Jong
Blog: hjalte.nl - github.com
i refered to "progarming/api help". In inventor 2018 you get to it like this:
Jelte de Jong
