ilogic Can't find coordinates of geometryintent
Hi all,
I am trying to create i kind of autoballoon function.
I found that it is pretty hard to move the leaderpoitn that has the arrow on it.
but now i want to use the location where the balloon leader is starting to relocate the balloons.
The startpoint of the leader is created using the 'creategeometryintent' function.
for this function i use a curve as input, and the output is a point2D.
now the problem is that when i want to read the coordinates point, but when i put this in a messagebox i get an error.
also when i create a paramter as a double and write the coordinate to this, it wont work.
can someone explain why i cannot read the coordinates of this point?
this code can be run from any drawing with at least 4 views in it, so feel free to try.
Dim oDrawing As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = oDrawing.ActiveSheet
Dim oView As DrawingView = oSheet.DrawingViews.Item(4)
Dim oReferDoc As AssemblyDocument = oView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oAssyDef As AssemblyComponentDefinition = oReferDoc.ComponentDefinition
Dim Occ As ComponentOccurrence
Dim oCurve As DrawingCurve
	For Each Occ In oAssyDef.Occurrences
		If oView.DrawingCurves(Occ).Count > 0 Then
			Dim oCurves As DrawingCurvesEnumerator = oView.DrawingCurves(Occ)
			 oCurve = oCurves.Item(1)
			 MsgBox("Curves found")
		Else
			GoTo Volgende
'Dim oDrawingCurve As DrawingCurve = oActiveSheet.DrawingViews.Item(4).DrawingCurves.Item(i)
			Dim oMidpoint As Point2d
		Try
			If oCurve.CurveType <> 5124 Then
				oMidpoint = oCurve.MidPoint
			Else
				oMidpoint = oCurve.CenterPoint
		Catch
		End Try
			    ' Set a reference to the TransientGeometry object.
			    Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
			    Dim oLeaderPoints As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
			    ' Create a couple of leader points.
			    Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidpoint.X + 10, oMidpoint.Y + 10))
			    Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidpoint.X + 10, oMidpoint.Y + 5))
			    ' Add the GeometryIntent to the leader points collection.
			    ' This is the geometry that the balloon will attach to.
			    Dim oGeometryIntent As GeometryIntent = oSheet.CreateGeometryIntent(oCurve)
				Dim xcord As Double = oGeometryIntent.PointOnSheet.X
				MsgBox(xcord)
'				MsgBox(oGeometryIntent.PointOnSheet.X & " " & oGeometryIntent.PointOnSheet.Y)
				Call oLeaderPoints.Add(oGeometryIntent)
			    ' Set a reference to the parent drawing view of the selected curve
			    Dim oDrawingView As DrawingView = oCurve.Parent
			    ' Set a reference to the referenced model document
			    Dim oModelDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
			    ' Check if a partslist or a balloon has already been created for this model
			    Dim IsDrawingBOMDefined As Boolean
			    IsDrawingBOMDefined = oDrawing.DrawingBOMs.IsDrawingBOMDefined(oModelDoc.FullFileName)
			    Dim oBalloon As Balloon
			    If IsDrawingBOMDefined Then
			        ' Just create the balloon with the leader points
			        ' All other arguments can be ignored
			        oBalloon = oDrawing.ActiveSheet.Balloons.Add(oLeaderPoints)
			    Else
			        ' First check if the 'structured' BOM view has been enabled in the model
			        ' Set a reference to the model's BOM object
			        Dim oBOM As BOM = oModelDoc.ComponentDefinition.BOM
			        If oBOM.StructuredViewEnabled Then
			            ' Level needs to be specified
			            ' Numbering options have already been defined
			            ' Get the Level ('All levels' or 'First level only')
			            ' from the model BOM view - must use the same here
			            Dim Level As PartsListLevelEnum
			            If oBOM.StructuredViewFirstLevelOnly Then
			                Level = kStructured
			            Else
			                Level = kStructuredAllLevels
			            oBalloon = oSheet.Balloons.Add(oLeaderPoints, , Level)
			        Else
			            Dim oNumberingScheme As NameValueMap= ThisApplication.TransientObjects.CreateNameValueMap
			            oNumberingScheme.Add ("Delimiter", ",")
			            oBalloon = oSheet.Balloons.Add(oLeaderPoints, , kStructuredAllLevels, oNumberingScheme)
Volgende:
		Next
Dim bloon As Balloon
Dim compare As String = ""
For Each bloon In oSheet.Balloons
	If compare = bloon.BalloonValueSets.Item(1).Value Then
		bloon.Delete
	Else
Next
Okay, So for intereseted people i have an update.
apparently the geometryintent is empty.
when checking the code in VBA the it is empty trhough the entire code.
so how the balloon can connect to a line is very strange.
Also i found out that a balloon doesnt strat at the arrow, but at the balloon(circle),
This is something different then when you want to place them manually.
I Also tried moving the rootnode of the balloon using a prefixed point2D.
I don't get any errors when doing this, but it also doesn't move anything.
How is it not possible to modify anything to a balloon when you have already placed them.
so i have two options that both don't work (in red):
1: read the point where the balloon is connected to the part, and then give it a leaderpoint accordingly
2: read the last leadernode of the balloon and then move the rootnode accordingly
is there any option to do this in code or is this so deep into the program that it is not possible?
Kind regards,
JelteDeJong
hi in your code where you try to get the GeometryIntent, i dont see a property/eNum to tell inventor wich point on the curve you want to use. therefor you need to use the enum: "PointIntentEnum". Pay attension that not all types of curves have the same points. for example a line does not have a centerpoint (that is for circular curves) but does have a mid point.
you could try to replace the line:
with:
    Dim geoType = oCurve.Segments.Item(1).GeometryType
    If (geoType = Curve2dTypeEnum.kLineSegmentCurve2d) Then
        oGeometryIntent = sheet.CreateGeometryIntent(oCurve, PointIntentEnum.kStartPointIntent)
    ElseIf (geoType = Curve2dTypeEnum.kCircleCurve2d) Then
        oGeometryIntent = sheet.CreateGeometryIntent(oCurve, PointIntentEnum.kCircularLeftPointIntent)
for your situation you might want to change the PointIntentEnum.?????? to something else. See help for all options.
(disclamer: i did not have time to try this out but expect that it would work.)
Jelte de Jong
Blog: hjalte.nl - github.com
Thanks for the answer!
I didn't know i could specify a certain type of point to the geometryintent.
I also found out how to move the balloon around the sheet.
It is not possible moving the balloon with a X and Y coordinate seperate, but you have to assign a point2D to the position, something like this:
Dim Point As Point2d = oTG.CreatePoint2d(6, 10)
oBalloon.Leader.AllNodes.Item(1).Position = Point
i will post my code here if i got it working functionally
kind regards,
so for everyone interested in an autoballoon function. the code i have so far works.
Only thing to modify is that the leaders can intersect each other, so that is something to improve.
the code is created with the intention to only balloon the iso view that is view 4.
Imports Inventor.CurveTypeEnum
Imports System.IO
Sub Main()
Dim oLine As DrawingCurve
			Dim oCollection As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
				For Each oCurve In oCurves
					If oCurve.CurveType = kLineSegmentCurve Then
					Call oCollection.Add(oCurve)
				Next
			If oCollection.Count > 0 Then
				oLine = oCollection.Item(1)
			Else
				oLine = oCurves.Item(1)
'			 oCurve = oCurves.Item(1)
'			 MsgBox("Curves found")
		Else
			GoTo Volgende
		Try
			If oLine.CurveType <> 5124 Then
				oMidpoint = oLine.MidPoint
				oGeometryIntent = oSheet.CreateGeometryIntent(oLine, PointIntentEnum.kMidPointIntent)
			Else
				oMidpoint = oLine.CenterPoint
				oGeometryIntent = oSheet.CreateGeometryIntent(oLine, PointIntentEnum.kCircularLeftPointIntent)
		Catch
		End Try
			    Dim VmX As Double = oView.Center.X
				Dim VmY As Double = oView.Center.Y
				Dim PX As Double = oMidpoint.X
				Dim PY As Double = oMidpoint.Y
				Dim Vw As Double = oView.Width
				Dim Vh As Double = oView.Height
'				MsgBox("VmX: " & VmX & " VmY: " & VmY & vbNewLine & "PX: " & PX & " PY: " & PY & vbNewLine & "Vw: " & Vw & " Vh: " & Vh)
				If PX < VmX And PY > VmY Then
					If PY < (((VmX - PX) / (0.5 * Vw)) * (0.5 * Vh)) + VmY Then
						Call oLeaderPoints.Add(oTG.CreatePoint2d(VmX - (0.5 * Vw) - 1, PY)) 'A
					Else
						Call oLeaderPoints.Add(oTG.CreatePoint2d(PX, VmY + (0.5 * Vh) + 1)) 'B
				ElseIf PX > VmX And PY > wmy Then
					If PY < (((PX - VmX) / (0.5 * Vw)) * (0.5 * Vh)) + VmY Then
						Call oLeaderPoints.Add(oTG.CreatePoint2d(VmX + (0.5 * Vw) + 1, PY)) 'D
					Else
						Call oLeaderPoints.Add(oTG.CreatePoint2d(PX, VmY + (0.5 * Vh) + 1)) 'C
				ElseIf PX > VmX And PY < VmY Then
					If PY > (((PX - VmX) / (0.5 * Vw)) * (0.5 * Vh)) + VmY Then
						Call oLeaderPoints.Add(oTG.CreatePoint2d(VmX + (0.5 * Vw) + 1, PY)) 'E
					Else
						Call oLeaderPoints.Add(oTG.CreatePoint2d(PX, VmY - (0.5 * Vh) - 1)) 'F
				ElseIf PX < VmX And PY < VmY Then
					If PY > (((VmX - PX) / (0.5 * Vw)) * (0.5 * Vh)) + VmY Then
						Call oLeaderPoints.Add(oTG.CreatePoint2d(VmX - (0.5 * Vw) - 1, PY)) 'H
					Else
						Call oLeaderPoints.Add(oTG.CreatePoint2d(PX, VmY - (0.5 * Vh) - 1)) 'G
'				Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
'			    Dim oLeaderPoints As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
'			    Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidpoint.X + 10, oMidpoint.Y + 10))
			    Else
			                Level = kStructured
			            Else
			        Else
Volgende:
		Next
Trace.WriteLine("Bloon count: " & oSheet.Balloons.Count)
	Trace.WriteLine("Bloon value: " & bloon.BalloonValueSets.Item(1).Value)
		bloon.Delete
	Else
'	leader = bloon.Leader.AllNodes.Item(1) To bloon.Leader.AllNodes.Item(2)
Next
Dim TColl As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection	'top
Dim RColl As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection 'Right
Dim BColl As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection 'Bottom
Dim LColl As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection 'Left
Dim TData As New List(Of Tuple(Of Integer,Double))
Dim RData As New List(Of Tuple(Of Integer,Double))
Dim BData As New List(Of Tuple(Of Integer,Double))
Dim LData As New List(Of Tuple(Of Integer,Double))
Dim count As Integer = 1
	If bloon.Position.Y > oView.Center.Y + (oView.Height * 0.5) Then
		TData.Add(New Tuple(Of Integer, Double)(Count, bloon.Position.X))
	ElseIf bloon.Position.X > oView.Center.X + (oView.Width * 0.5) Then
		RData.Add(New Tuple(Of Integer, Double)(Count, bloon.Position.Y))
	ElseIf bloon.Position.Y < oView.Center.Y - (oView.Height * 0.5) Then
		BData.Add(New Tuple(Of Integer, Double)(Count, bloon.Position.X))
	ElseIf bloon.Position.X < oView.Center.X - (oView.Width * 0.5) Then
		LData.Add(New Tuple(Of Integer, Double)(Count, bloon.Position.Y))
count = count+1
Next
If TData.Count>1 Then
	TData.Sort(New Comparison(Of Tuple(Of Integer, Double))(AddressOf ComparisonTwoTuples))
	Movebloon(TData, 0.75, 0)
If RData.Count>1 Then
	RData.Sort(New Comparison(Of Tuple(Of Integer, Double))(AddressOf ComparisonTwoTuples))
	Movebloon(RData, 0, 0.75)
If BData.Count>1 Then
	BData.Sort(New Comparison(Of Tuple(Of Integer, Double))(AddressOf ComparisonTwoTuples))
	Movebloon(BData, 0.75, 0)
If LData.Count>1 Then
	LData.Sort(New Comparison(Of Tuple(Of Integer, Double))(AddressOf ComparisonTwoTuples))
	Movebloon(LData,0, 0.75)
End Sub
Function Movebloon(Data As List(Of Tuple(Of Integer, Double)), moveX As Double, moveY As Double)
Dim drawdoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = drawdoc.ActiveSheet
Trace.WriteLine("count " & Data.count)
For z = 1 To Data.Count-1
Trace.WriteLine("Z:" & z)
'MsgBox(TData.Item(Z).tostring)
Dim CurrItem As Integer = Split(Mid(Data.Item(z-1).tostring, 2, Len(Data.Item(z-1).tostring) -2), ",", 2)(0)
Dim NextItem As Integer = Split(Mid(Data.Item(z).tostring, 2, Len(Data.Item(z).tostring) -2), ",", 2)(0)
Trace.WriteLine("Curr:" & CurrItem)
Dim CurrCoord As Double = oSheet.Balloons.Item(CurrItem).Position.X  'Split(Mid(Data.Item(z).tostring, 2, Len(Data.Item(z).tostring) -2), ",",2)(1)
Dim NextCoord As Double = Split(Mid(Data.Item(z).tostring, 2, Len(Data.Item(z).tostring) -2), ",", 2)(1)
Trace.WriteLine("Balloon value: " & oSheet.Balloons.Item(CurrItem).BalloonValueSets.Item(1).Value)
Trace.WriteLine("result" & (NextCoord - CurrCoord + 0.6))
	If NextCoord < CurrCoord + 0.6 Then
		Point = oTG.CreatePoint2d(oSheet.Balloons.Item(CurrItem).Position.X + moveX, oSheet.Balloons.Item(CurrItem).Position.Y + moveY)
		oSheet.Balloons.Item(NextItem).Leader.AllNodes.Item(1).Position = point
Next
End Function
Function ComparisonTwoTuples(ByVal tupleA As Tuple(Of Integer, Double), ByVal tupleB As Tuple(Of Integer, Double)) As Double
    ' Compare the first Item of each tuple in ascending order.
    Dim part1 As Double = tupleA.Item2
    Dim part2 As Double = tupleB.Item2
    Dim compareResult As Double = part1.CompareTo(part2)
    ' If not equal, return the comparison result.
    If compareResult <> 0 Then
        Return compareResult
    ' Compare the second item of each tuple in descending order.
    Return tupleB.Item2.CompareTo(tupleA.Item2)
End Function
