ThisApplication.ActiveDocument.ComponentDefinition fail
Darkforce_the_ilogic_guy
Advisor Advisor
why does this sometimes fail , and sometimes not
Dim oAsmCompDef As AssemblyComponentDefinition
 'illogic code
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
both files are made form the same templet
and add some files to it form vault.
one of them fail and one of them do not how can it be and is there a way to not make it fail ?
Sergio.D.Suárez
If you are going to work in ilogic, replace the string "ThisApplication.ActiveDocument" with the
"ThisDoc.Document"
It usually gives problems when it comes to active documents. (In VBA this is not so easy, since the ThisDoc.Document statement does not exist)
For example if you have an assembly file with a component that has an internal rule and this defines the document as "ThisApplication.ActiveDocument"
From the assembly you edit component and execute the rule, it will give an error because your active document is not that of the component. Your active document is the one of assembly.
In contrast if in the rule of ilogic would have placed   "ThisDoc.Document "  there would be no problems.
I hope I have been clear and that this helps your problem.
Best Regards!!
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
bradeneuropeArthur
@Sergio.D.Suárez
Public Sub main()
Dim a As Document
Set a = ThisDocument.InventorDocument
MsgBox a.FullDocumentName
End Sub
Public Sub main()
Dim a As Document
End Sub
both work!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Sergio.D.Suárez
I already told you the other time that you were a genius   Smiley LOL, I in VBA activating and deactivating again and again !!!! Thank you very much @bradeneuropeArthur  !!!
Mechanical Designer
bradeneuropeArthur
@Sergio.D.Suárez
With pleasure...
Your thanks are appreciated very much.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
philip1009
ThisDoc.Document is the recommended callout for the document object, but it's all dependant on the context.  ThisDoc.Document refers to the document that the rule is called from, if you have Assembly1 and Assembly2 open, have Assembly2 as the active document and running the rule from Assembly1, ThisDoc.Document refers to Assembly1.
In the same situation if you're running the rule from Assembly1 but have Assembly2 active, ThisApplication.ActiveDocument will refer to Assembly2.
The last one to consider is ThisApplication.ActiveEditDocument, this is used for editing a sub-assembly in an active assembly, ActiveDocument will refer to the top-layer assembly, ActiveEditDocument refers to the current sub-assembly/part document that's being edited.
Also, you don't have to be specific with Component Definitions, Dimming as ComponentDefinition will work for all variations in the context of the document object it's called from.
