Hi, I'm using Inventor 2016 and I'm trying to create a vba form that would generate YConnectors. I've managed to draw the shape of the YConnector with surface bodies but I can't thicken them. Thera are three thicken features present (on lines 39, 43, 47) but only the first one of these will work. If I comment out thicken feature on line 39 then the thicken command on line 43 will work, but the one on line 47 won't
Below there is a relevant code snippet:
Imports Inventor
Imports System.Runtime.InteropServices
Imports System.Windows.Forms
Public Class Form1
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
Dim InventorApp As Inventor.Application
Try
InventorApp = Marshal.GetActiveObject("Inventor.Application")
MessageBox.Show("Connected To Inventor session")
Catch ex As Exception
MessageBox.Show("Failed to connect to inventor session")
End Try
If Not (InventorApp.ActiveDocument.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then 'Switch document subtype to sheet metal
End If
Dim oPartDoc As PartDocument
Dim oPartCompDef As SheetMetalComponentDefinition
'Dim oPartCompDef As ComponentDefinition
oPartDoc = InventorApp.ActiveDocument
oPartCompDef = oPartDoc.ComponentDefinition
Dim oThickenCollectorFaceCollection As FaceCollection
Dim oThickenInletFaceCollection1 As FaceCollection
Dim oThickenInletFaceCollection2 As FaceCollection
Dim oThickenCollector As ThickenFeature
Dim oThickenInlet1 As ThickenFeature
Dim oThickenInlet2 As ThickenFeature
oThickenCollectorFaceCollection = InventorApp.TransientObjects.CreateFaceCollection() 'Create face collection
oThickenCollectorFaceCollection.Add(oPartCompDef.Features(1).SurfaceBodies(1).Faces(1)) 'Add collector surface to face collection
oThickenCollector = oPartCompDef.Features.ThickenFeatures.Add(oThickenCollectorFaceCollection, Convert.ToDouble(CollectorThicknessTextBox.Text) / 10, PartFeatureExtentDirectionEnum.kPositiveExtentDirection, PartFeatureOperationEnum.kNewBodyOperation) 'Thicken collector
oThickenInletFaceCollection1 = InventorApp.TransientObjects.CreateFaceCollection() 'Create face collection
oThickenInletFaceCollection1.Add(oPartCompDef.Features(2).SurfaceBodies(1).Faces(1)) 'Add inlet 1 surface to face collection
oThickenInlet1 = oPartCompDef.Features.ThickenFeatures.Add(oThickenInletFaceCollection1, Convert.ToDouble(InletThicknessTextBox.Text) / 10, PartFeatureExtentDirectionEnum.kPositiveExtentDirection, PartFeatureOperationEnum.kNewBodyOperation) 'Thicken inlet 1
oThickenInletFaceCollection2 = InventorApp.TransientObjects.CreateFaceCollection() 'Create face collection
oThickenInletFaceCollection2.Add(oPartCompDef.Features(3).SurfaceBodies(1).Faces(1)) 'Add inlet 1 surface to face collection
oThickenInlet2 = oPartCompDef.Features.ThickenFeatures.Add(oThickenInletFaceCollection2, Convert.ToDouble(InletThicknessTextBox.Text) / 10, PartFeatureExtentDirectionEnum.kPositiveExtentDirection, PartFeatureOperationEnum.kNewBodyOperation) 'Thicken inlet 2
oPartDoc.Update()
End Sub
End Class
And a model it should work on:
I suspect that there is a problem with the way I'm using sheet metal environment because if I switch to normal part environment it works:
Imports Inventor
Public Class Form1
Try
End Try
oPartDoc.Update()
End Sub
End Class
hi, run your solution test.zip works all fine (inventor 2024), maybe it is the version of inventor
I've managed to solve it for now but I have to keep switching document's substyle from general part to sheet metal part and back.
