Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Showing results forĀ
Did you mean:Ā
Thicken feature in Sheet metal
2 REPLIES 2
piotrekdoro94
116 Views, 2 Replies
Hi, I'm using Inventor 2016 and I'm trying to create a vba form that would generate YConnectors. I've managed to draw the shape of the YConnector with surface bodies but I can't thicken them. Thera are three thicken features present (on lines 39, 43, 47) but only the first one of these will work. If I comment out thicken feature on line 39 then  the thicken command on line 43 will work, but the one on line 47 won't
Below there is a relevant code snippet:
Imports Inventor
Imports System.Runtime.InteropServices
Imports System.Windows.Forms
Public Class Form1
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        Dim InventorApp As Inventor.Application
        Try
            InventorApp = Marshal.GetActiveObject("Inventor.Application")
            MessageBox.Show("Connected To Inventor session")
        Catch ex As Exception
            MessageBox.Show("Failed to connect to inventor session")
        End Try
        If Not (InventorApp.ActiveDocument.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then 'Switch document subtype to sheet metal
        End If
        Dim oPartDoc As PartDocument
        Dim oPartCompDef As SheetMetalComponentDefinition
        'Dim oPartCompDef As ComponentDefinition
        oPartDoc = InventorApp.ActiveDocument
        oPartCompDef = oPartDoc.ComponentDefinition
        Dim oThickenCollectorFaceCollection As FaceCollection
        Dim oThickenInletFaceCollection1 As FaceCollection
        Dim oThickenInletFaceCollection2 As FaceCollection
        Dim oThickenCollector As ThickenFeature
        Dim oThickenInlet1 As ThickenFeature
        Dim oThickenInlet2 As ThickenFeature
        oThickenCollectorFaceCollection = InventorApp.TransientObjects.CreateFaceCollection() 'Create face collection
        oThickenCollectorFaceCollection.Add(oPartCompDef.Features(1).SurfaceBodies(1).Faces(1)) 'Add collector surface to face collection
        oThickenCollector = oPartCompDef.Features.ThickenFeatures.Add(oThickenCollectorFaceCollection, Convert.ToDouble(CollectorThicknessTextBox.Text) / 10, PartFeatureExtentDirectionEnum.kPositiveExtentDirection, PartFeatureOperationEnum.kNewBodyOperation) 'Thicken collector
        oThickenInletFaceCollection1 = InventorApp.TransientObjects.CreateFaceCollection() 'Create face collection
        oThickenInletFaceCollection1.Add(oPartCompDef.Features(2).SurfaceBodies(1).Faces(1)) 'Add inlet 1 surface to face collection
        oThickenInlet1 = oPartCompDef.Features.ThickenFeatures.Add(oThickenInletFaceCollection1, Convert.ToDouble(InletThicknessTextBox.Text) / 10, PartFeatureExtentDirectionEnum.kPositiveExtentDirection, PartFeatureOperationEnum.kNewBodyOperation) 'Thicken inlet 1
        oThickenInletFaceCollection2 = InventorApp.TransientObjects.CreateFaceCollection() 'Create face collection
        oThickenInletFaceCollection2.Add(oPartCompDef.Features(3).SurfaceBodies(1).Faces(1)) 'Add inlet 1 surface to face collection
        oThickenInlet2 = oPartCompDef.Features.ThickenFeatures.Add(oThickenInletFaceCollection2, Convert.ToDouble(InletThicknessTextBox.Text) / 10, PartFeatureExtentDirectionEnum.kPositiveExtentDirection, PartFeatureOperationEnum.kNewBodyOperation) 'Thicken inlet 2
        oPartDoc.Update()
    End Sub
End Class
And a model it should work on:
I suspect that there is a problem with the way I'm using sheet metal environment because if I switch to normal part environment it works:
Imports Inventor
Public Class Form1
        Try
        End Try
        oPartDoc.Update()
    End Sub
End Class
Labels (2)
2 REPLIES 2
nstevelmans
in reply to: piotrekdoro94
hi, run your solution test.zip works all fine  (inventor 2024), maybe it is the version of inventor
I've managed to  solve it for now but I have to keep switching document's substyle from general part to sheet metal part and back.
Technology Administrators
