Textbox Prompt Emtry Formatted Text
Message 1 of 9
I would like to change the style (strikethrough) of a prompted entry text box.
I tried using the following code but it doesn't work:
strFormattedText = dctPromptedEntries.Item("SQUARE").FormattedText
strFormattedText = Replace(strFormattedText, "<Prompt", "<StyleOverride Strikethrough='False'><Prompt")
strFormattedText = Replace(strFormattedText, "</Prompt>", "</Prompt></StyleOverride>")
dctPromptedEntries.Item("SQUARE").FormattedText = strFormattedText
I tried getting the formatted text of the textbox however only the prompt property is being returned.
What is the correct way in setting the style of a prompted entry textbox?
Replies (8)
Message 2 of 9
Rob67ert
I have been playing with it to.
This is my solution:
SyntaxEditor Code Snippet
    TempPartNo = "<StyleOverride Font='ISOCP_IV25' FontSize='0.5' Bold='False' Strikethrough='True'>" & TempPartNo & "</StyleOverride>"
    oSK.TextBoxes.Item(1).FormattedText = TempPartNo
 Hope it will help you.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Message 3 of 9
MechMachineMan
1) With how your code starts, we don't know what collection you are actually pulling this info from to be able to help you with any little nuances it may be. I'm ASSUMING that dctPromptedEntries is a collection of TextBoxes which may or may not include prompted entry text.
2) You are missing a closing ">"
3) Have you tried checking what the outputs of each line are to ensure that nothing is going wrong?
ie;
MsgBox("Line1: " & strFormattedText)
MsgBox("Line2: " & strFormattedText)
MsgBox("Line3: " & strFormattedText)
MsgBox("Line4: " & dctPromptedEntries.Item("SQUARE").FormattedText)
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 4 of 9
Sorry for the late reply. I just came back with this issue.
1. Yes, you're correct. dctPromptedEntries is a collection of prompted entry textbox.
2. I'm not sure of what line you are referring for missing ">".
3. I already tried that code to check the returned string but nothing's wrong.
I tried getting the formatted text of the textbox and set it again to textbox but still it fails. See code below.
I tried a suggestion from other post to turn off the textbox border and remove the constraints but still same error.
Message 5 of 9
wayne.brill
I would need to research this. Please upload an Inventor Drawing with the TextBox you are trying to change. Also if you could provide a complete (but small) code example that shows the problem that would be helpful.
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
Message 6 of 9
Hi wayne,
See code below and attached file for the Inventor drawing.
oTitleBlockED = m_InventorApp.ActiveDocument.ActiveSheet.TitleBlock
dctPromptedEntries = GetPrompEntries()
If UCase(strTubePattern) = "TRIANGULAR" Then
	setTextBoxValues(dctPromptedEntries.Item("TRIANGULAR"), "TRIANGULAR")
	dctPromptedEntries.Item("TRIANGULAR").FormattedText = strFormattedText
ElseIf UCase(strTubePattern) = "SQUARE" Then
	setTextBoxValues(dctPromptedEntries.Item("SQUARE"), "SQUARE")
Private Function GetPrompEntries() As Dictionary(Of String, TextBox)
	Dim otextboxes As TextBoxes
	Dim oTextBox As TextBox
	Dim dctPromptEntries As New Dictionary(Of String, TextBox)
	Dim oActiveDocument As DrawingDocument
	oActiveDocument = m_InventorApp.ActiveDocument
	Dim oTitleBlock As TitleBlock
	oTitleBlock = oActiveDocument.ActiveSheet.TitleBlock
	Dim strValue As String
	If Not oTitleBlock Is Nothing Then
		otextboxes = oTitleBlock.Definition.Sketch.TextBoxes
		For Each oTextBox In otextboxes
			strValue = Trim(oTextBox.Text)
			If InStr(UCase(oTextBox.FormattedText), "</PROMPT>") <> 0 Then
				If Not dctPromptEntries.ContainsKey(strValue) Then
					dctPromptEntries.Add(strValue, oTextBox)
			ElseIf UCase(strValue) = "ELLIP" Or UCase(strValue) = "FLAT" Or UCase(strValue) = "DISH" _
				Or UCase(strValue) = "CONIC" Or UCase(strValue) = "HEMISPH" Then
		Next
	Return dctPromptEntries
End Function
Public Sub setTextBoxValues(ByVal oTextbox As TextBox, strValue As String)
        oTitleBlockED.SetPromptResultText(oTextbox, strValue)
End Sub
Hope you can help us on this.
Message 7 of 9
Hi wayne,
See attached file for the Inventor drawing.
Thank you.
Message 8 of 9
wayne.brill
I find that the Edit method of the TitleBlockDefinition needs to be called and the TextBox needs to come from the DrawingSketch that is being edited.
Here is an update to your code. This is from a .NET forms application. The logic for getting the correct TextBox may need to be improved but the code does show that changing the FormattedText property of a TextBox in a TitleBlockDefinition can work.
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        'WB added
        Dim m_InventorApp As Inventor.Application = Nothing '= AddinGlobal.InventorApp '<- this gives me the Application
        Try
            m_InventorApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
        Catch ex As Exception
        End Try
        Dim oTitleBlockED As TitleBlock
        Dim dctPromptedEntries As Dictionary(Of String, TextBox)
        dctPromptedEntries = GetPrompEntries(m_InventorApp)
        ' Dim strTubePattern As String = "Triangular"
        Dim strTubePattern As String = "Square"
        Dim strFormattedText As String
            setTextBoxValues(dctPromptedEntries.Item("TRIANGULAR"), "TRIANGULAR", oTitleBlockED)
            setTextBoxValues(dctPromptedEntries.Item("SQUARE"), "SQUARE", oTitleBlockED)
            ' strFormattedText = Replace(strFormattedText, "<Prompt", "<StyleOverride Strikethrough='False'><Prompt")
            'WB added - wanted to see the strike through in the text (worked ok)
            strFormattedText = Replace(strFormattedText, "<Prompt", "<StyleOverride Strikethrough='True'><Prompt")
            'WB added
            Dim oTitleBlockDef As TitleBlockDefinition
            oTitleBlockDef = m_InventorApp.ActiveDocument.TitleBlockDefinitions("Heat Exchanger")
            Dim oSketch As DrawingSketch = Nothing
            'Edit the TitleBlockDefinition, passing in a DrawingSketch that will be instantiated
            Call oTitleBlockDef.Edit(oSketch)
            'WB commented
            ' oTextBox = dctPromptedEntries.Item("SQUARE")
            'WB added for each
            'Go through the TextBoxes in in the Sketch being edited
            For Each oTextBox In oSketch.TextBoxes
                'Debug.Print(oTextBox.Text)
                If oTextBox.Text.Contains("SQUARE") Then
                    'This works without error for me (TextBox is from DrawingSketch being edited)
                    oTextBox.FormattedText = strFormattedText
                    Exit For
                'WB commented
                'dctPromptedEntries.Item("SQUARE").FormattedText = strFormattedText
            Next oTextBox
            oTitleBlockDef.ExitEdit(True)
    End Sub
    Private Function GetPrompEntries(m_InventorApp As Inventor.Application) As Dictionary(Of String, TextBox)
            Next
    End Function
    Public Sub setTextBoxValues(ByVal oTextbox As TextBox, strValue As String, oTitleBlockED As TitleBlock)
    End Sub
Wayne
Wayne Brill
Message 9 of 9
Hi wayne,
Thank you very much for reply. It works fine now.
