Textbox with Border option is only available to a text entity created within a sketch. LeaderNote text although uses the same editor, has that feature disabled (aka not present). The same is for textboxes added directly to a sheet (no border option).
In Inventor 2019, I can not use GIU to enable a leader text box's border. Can you screencast record how you do that? Perhaps I can find the 'object' in question.
I love to be proven wrong, it teaches me new things. Ok so the button I was looking for is greyed out, and the method you are using is completely different. Tomorrow when I'm back in the office, I will create this object, and break down the item in .Net to find if this is a text format option or what.
Well its not in the Formatted Text, its not in the Dimension Style, its not a hidden Attribute value. Its not a special Background Color (similar to how if you set a certain date, the program assumes 'unchecked'). Not fully exhausting the search, it could be an associated entity. More likely since it is a new feature, its a missing property reference in the API. Can an Autodesk employee confirm this?
Who cares about it - let's vote for this idea 👍 👍👍
https://forums.autodesk.com/t5/inventor-ideas/text-border-functionality-api-support/idi-p/9707489
