Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Suppress Part Pattern Element from iLogic Rule within Assembly
2 REPLIES 2
KarlH_
193 Views, 2 Replies
Hey all,
I have written a couple of iLogic rules that execute within a Part, that can suppress various elements within a parts Pattern Feature.
Unsuppress all Pattern Elements;
Dim oPattern As RectangularPatternFeature
oPattern = ThisDoc.Document.ComponentDefinition.Features.RectangularPatternFeatures.Item("Rectangular Pattern1")
Dim oElement As FeaturePatternElement
For Each oElement In oPattern.PatternElements
    If oElement.Index > 1 Then
        oElement.Suppressed = False
    End If
Next
ThisDoc.Document.Update
Suppress the last element;
oElement = oPattern.PatternElements.Item(oPattern.PatternElements.Count)
oElement.Suppressed = True
ThisDoc.Document.update
Suppress the desired element;
Dim number As Integer = 5
    If oElement.Index = number Then
    End If
Next
And suppress the middle element(s) - pending odd or even qty.
If oPattern.PatternElements.Count Mod 2 = 0 Then 'if the count is even
        If oElement.Index = (oPattern.PatternElements.Count / 2) Or oElement.Index = (oPattern.PatternElements.Count / 2) + 1 Then
        End If
    Next
Else 'if the count is odd
        If oElement.Index = (oPattern.PatternElements.Count + 1) / 2 Then
        End If
    Next
End If
These all work well from a testing point of view, but perhaps they could be refactored or simplified (and by all means, please feel free to comment/update).
But I'm now needing a hand in having these rules executing from a parent assembly of that part, that contains the parts Pattern Feature - I just can't seem to get the syntax right.
If worst comes to worst, I guess I can leave these rules nested within the Part, and call the parts iLogic rules via the assemblies main iLogic sub, but would prefer if I could alter these rules so that they're run from the parent assembly, keeping the part free from iLogic rules.
Appreciate any help, thanks!
Labels (2)
2 REPLIES 2
Cadkunde.nl
in reply to: KarlH_
Nothing to mention on your code, seems fine.
To go through parts in an assembly, please look here:
https://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html
Maybe you need to activate the document before you change pattern.
You can do that with:
Dim occdoc As PartDocument = oOcc.Definition.document
occdoc.activate
When you do that, you need to change thisdoc.document to occdoc in your code
If you know the exact name of the component:
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oOccs As Inventor.ComponentOccurrences = oDoc.ComponentDefinition.Occurrences
Dim oPrtDoc As PartDocument = oOccs.ItemByName("bla").Definition.Document
wfajber
in reply to: Cadkunde.nl
And just a reminder that this type of thing breaks if you are ‘Load Express’ on your assembly. It works fine but if the your assembly file is express loaded, the definition is not yet fully loaded, and thus not editable.
someone else had a similar issue their code in a large assembly, which should have otherwise worked.
