I've got code that goes through an assembly and finds all of the documents with a certain property set. It then adds it to a list with the stock number, file path, and qty. The issue I'm running into is if there is a main assembly (Call it A) with multiple sub assemblies (Call it B) it will show the amount required for that sub assembly but if sub assembly B has another sub assembly (call it B.1) it doesn't multiply the quantity required just shows the total quantity required for one B assembly. It also doesn't account if sub C is in other sub assemblies. Below is a snippet of the code I have that
Private Function GetBOMstructure(ByVal oBOM As BOM) As BOMView
Dim sLanguageBOM, sSortItem As String
Select Case ThisApplication.LanguageCode
Case "en-US"
sLanguageBOM = "Structured"
Case Else
Return Nothing
End Select
If oBOM.StructuredViewEnabled = False Then oBOM.StructuredViewEnabled = True
If oBOM.StructuredViewFirstLevelOnly = True Then oBOM.StructuredViewFirstLevelOnly = False
Return oBOM.BOMViews.Item(sLanguageBOM)
End Function
Private Function GetListComponents(ByVal oBOMRows As BOMRowsEnumerator, ByRef oListComp As Object)
Dim oCompDef As ComponentDefinition
For Each oRow As BOMRow In oBOMRows
oCompDef = oRow.ComponentDefinitions.Item(1)
Dim oDoc As Document = oCompDef.Document
If oDoc.PropertySets.Item("Design Tracking Properties").Item("Cost Center").Value = "ACC" Then
Dim sStokNumb As String = oDoc.PropertySets.Item("Design Tracking Properties").Item("Stock Number").Value
'Dim folderpath As String = oDoc.PropertySets.Item("Design Tracking Properties").Item("Location").Value
Dim folderpath As String = oDoc.File.FullFileName
'defines backslash as the subdirectory separator
Dim strCharSep As String = System.IO.Path.DirectorySeparatorChar
'find the postion of the last backslash in the path
FNamePos = InStrRev(folderpath, "\", -1)
'get the file name with the file extension
Name = Right(folderpath, Len(folderpath) -FNamePos)
'get the path of the folder containing the file
Folder_Location = Left(folderpath, Len(folderpath) -Len(Name) -1)
'Sets export location for batch plot pdf location
Dim FilePath As String = "X:\7 - Design\0 - Batch Plot Drawings\" + Folder_Location.Substring(16)
Dim NewFilePath As String = FilePath + "\"
'i = MessageBox.Show("The Value you entered was incorrect " & NewFilePath, "My iLogic Dialog", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
'Used if folder isn't in right location
Else
oListComp(sStokNumb + NewFilePath) = oListComp(sStokNumb + NewFilePath) + oRow.ItemQuantity
End If
If oRow.ChildRows IsNot Nothing Then
GetListComponents(oRow.ChildRows, oListComp)
End If
Next
End Function
Hi @kwarrenH4ZT3. It seems clear that the code you posted is just part of a larger block of code, because there does not appear to be a Sub Main or a declaration line for the oListComp variable. Have you considered using the ComponentOccurrences.AllReferencedComponents(Object) method? You can supply a DocumentDescriptor, ComponentOccurrence, or Document as input, and it will return a ComponentOccurrencesEnumerator containing every component that references the input. You may be able to use that from the top/main assembly's AssemblyComponentDefinition.Occurrences property, and it will reach every level of the assembly. Then you could iterate the components in the returned collection to gather the needed data. Just one thought that crossed my mind when I read your post.
Wesley Crihfield
(Not an Autodesk Employee)
@WCrihfield Yes Below is the full code. I can look into using the all referenced components. If I used the all referenced components would it also take include any of the files that the bom structure is set to reference? We do use reference a lot and the iLogic I have right now doesn't include the reference files which I want to keep that way. I'm sure I could set it to exclude any with the bom structure of reference.
Sub Main()
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oDrawDoc As DrawingDocument = oDoc
Dim oSheet As Sheet = oDrawDoc.Sheets.Item(1)
oRevTableDateColumn = 1
If oSheet.RevisionTables.Count > 0
Dim oTable As RevisionTable = oSheet.RevisionTables.Item(1)
Dim oRows As RevisionTableRows = oTable.RevisionTableRows
Dim oRow As RevisionTableRow = oRows.Item(oRows.Count)
RevCheck = oRow.Item(oRevTableDateColumn).Text
Else
i = MessageBox.Show("Place a revision table!", "Need Revision Table", MessageBoxButtons.OK, MessageBoxIcon.Warning, MessageBoxDefaultButton.Button1)
Return
End If
If TypeOf oDoc Is DrawingDocument Then
If oSheet.DrawingViews.Count <> 0 Then
Dim oView As DrawingView = oSheet.DrawingViews.Item(1)
Dim oRefDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
If TypeOf oRefDoc Is AssemblyDocument Then
Dim oAssDoc As AssemblyDocument = oRefDoc
Dim oBOM As BOM = oAssDoc.ComponentDefinition.BOM
Dim oBOMView As BOMView = GetBOMstructure(oBOM)
If oBOMView Is Nothing Then Exit Sub
Dim oListComp As Object = CreateObject("Scripting.Dictionary")
Call GetListComponents(oBOMView.BOMRows, oListComp)
Dim sNameTable As String = "ACC LIST - " & System.IO.Path.GetFileNameWithoutExtension(oAssDoc.FullDocumentName)
Call CreatTable(oSheet, oListComp, sNameTable)
Call ExportList(RevCheck, sNameTable)
Call PID(RevCheck, sNameTable)
Else
MessageBox.Show("A table can only be created for AssemblyDocument.", "Error!", MessageBoxButtons.OK, MessageBoxIcon.Error)
End If
Else
MessageBox.Show("There are no DrawingViews on the first sheet.", "Error!", MessageBoxButtons.OK, MessageBoxIcon.Error)
End If
Else
MessageBox.Show("Active document is not Drawing Document.", "Error!", MessageBoxButtons.OK, MessageBoxIcon.Error)
End If
Events()
End Sub
Case "en-US"
Case Else
Return Nothing
End Select
End Function
If Not oListComp(sStokNumb + NewFilePath).exists(sStokNumb) Then
oRow = oRow + oRow.ItemQuantity
' oListComp(sStokNumb + NewFilePath).add.oRow.ItemQuanity
Else
End If
End If
End If
Next
End Function
Private Function CreatTable(ByVal oSheet As Sheet, ByVal oListComp As Object, ByVal sNameTable As String)
Dim oCustomTable As CustomTable
For Each otable As CustomTable In oSheet.CustomTables
If otable.Title = sNameTable Then
oCustomTable = otable
End If
Next
If oCustomTable Is Nothing Then
Dim oTitles(3) As String
oTitles(0) = "ACC #"
oTitles(1) = "STOCK NUMBER"
oTitles(2) = "QTY"
oTitles(3) = "HYPERLINK"
Dim oPlacementPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(.9525, 14.6288)
oCustomTable = oSheet.CustomTables.Add(sNameTable, oPlacementPoint, 4, oListComp.Count, oTitles)
oCustomTable.Columns.Item(1).Width = 2
oCustomTable.Columns.Item(2).Width = 6
oCustomTable.Columns.Item(3).Width = 2
oCustomTable.Columns.Item(4).Width = .001
oCustomTable.ShowTitle = True
'oCustomTable.TableDirection = kBottomUpDirection
'oCustomTable.HeadingPlacement = kHeadingAtBottom
oCustomTable.WrapAutomatically = False
'oCustomTable.MaximumRows=30
oHeightCustomTable = oCustomTable.RangeBox.MaxPoint.Y - oCustomTable.RangeBox.MinPoint.Y
oTablePt = ThisApplication.TransientGeometry.CreatePoint2d(.9525, oHeightCustomTable + .9525)
oCustomTable.Position = oTablePt
Else
If oCustomTable.Rows.Count < oListComp.Count Then
For i = oCustomTable.Rows.Count + 1 To oListComp.Count
oCustomTable.Rows.Add()
Next i
Else If oCustomTable.Rows.Count > oListComp.Count Then
For i = oCustomTable.Rows.Count To oListComp.Count + 1 Step -1
oCustomTable.Rows.Item(i).Delete()
Next i
End If
End If
Dim iList As Long = 1
For Each Item In oListComp
oCustomTable.Rows.Item(iList).Item(1).Value = iList
oCustomTable.Rows.Item(iList).Item(2).Value = Item.Substring(0, Item.IndexOf("X:\"))
oCustomTable.Rows.Item(iList).Item(3).Value = oListComp(Item)
oCustomTable.Rows.Item(iList).Item(4).Value = Item.Remove(0, Item.IndexOf("X:\"))
iList += 1
Next
End Function
Hi @kwarrenH4ZT3 . I recognize this code, but I see you've added a lot of changes. I reworked the GetListComponents() function as written by Mr. @WCrihfield above. I hope this is exactly what you needed.
Sub Main()
Else
Return
End If
Dim oOccs As ComponentOccurrences = oAssDoc.ComponentDefinition.Occurrences
For Each oRefDoc In oAssDoc.AllReferencedDocuments
Dim iQ As Integer = oOccs.AllReferencedOccurrences(oRefDoc).Count
If iQ = 0 Then Continue For
Call GetListComponents(oRefDoc, iQ, oListComp)
Next
Else
End If
Else
End If
Else
End If
Events()
End Sub
Private Function GetListComponents(ByVal oDoc As Document, ByVal iQ As Integer, ByRef oListComp As Object)
Dim oDesign As PropertySet = oDoc.PropertySets("Design Tracking Properties")
If oDesign("Cost Center").Value <> "ACC" Then Exit Function
Dim sStokNumb As String = oDesign("Stock Number").Value
Dim NewFilePath As String = "X:\7 - Design\0 - Batch Plot Drawings\" + Folder_Location.Substring(16) + "\"
oListComp(sStokNumb + NewFilePath) = oListComp(sStokNumb + NewFilePath) + iQ
End Function
End If
Next
oTitles(2) = "QTY"
Else
Next i
Next i
End If
End If
iList += 1
Next
End Function
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
@Andrii_Humeniuk This works great the only issue I have is if I set an assembly to reference it still counts it in the list. Is there a way I can get it to not count any occurrence that has the bom structure set to reference? Other then that it works great!
You need to add this line of code between lines 47-48.
If oDoc.ComponentDefinition.BOMStructure = kReferenceBOMStructure Then Exit Function
@Andrii_Humeniuk If I change the BOM Structure from the main assembly for individual assemblies it still counts all that are placed in the assembly.
Hi @kwarrenH4ZT3 . Now I modified the GetListComponents() function to work with Occurrences. Note that the current Occurrence check on lines 45-47 uses a GoTo statement to be able to process components in the middle of the current Occurrence, if you need to skip it and not read the components in the subassembly you need to replace GoTo SkipWritingList with Continue For
Sub Main()
Else
Return
End If
Dim oListComp As New Dictionary(Of String, Integer)
Call GetListComponents(oOccs, oListComp)
Else
End If
Else
End If
Else
End If
Events()
End Sub
Private Function GetListComponents(ByVal oOccs As ComponentOccurrences, ByRef oListComp As Dictionary(Of String, Integer))
For Each oOcc As ComponentOccurrence In oOccs
Dim oDoc As Document = oOcc.Definition.Document
If oOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Or
oOcc.Definition.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Or
oDesign("Cost Center").Value <> "ACC" Then GoTo SkipWritingList
If oListComp.ContainsKey(sStokNumb & NewFilePath) Then
oListComp(sStokNumb & NewFilePath) = oListComp(sStokNumb & NewFilePath) + 1
Else
oListComp.Add(sStokNumb & NewFilePath, 1)
End If
SkipWritingList :
If oOcc.SubOccurrences IsNot Nothing Then
If oOcc.SubOccurrences.Count <> 0 Then Call GetListComponents(oOcc.SubOccurrences, oListComp)
End If
Next
End Function
Private Function CreatTable(ByVal oSheet As Sheet, ByVal oListComp As Dictionary(Of String, Integer), ByVal sNameTable As String)
End If
Next
oTitles(2) = "QTY"
Else
Next i
Next i
End If
End If
oCustomTable.Rows.Item(iList).Item(2).Value = Item.Key.Substring(0, Item.Key.IndexOf("X:\"))
oCustomTable.Rows.Item(iList).Item(3).Value = Item.Value
oCustomTable.Rows.Item(iList).Item(4).Value = Item.Key.Remove(0, Item.Key.IndexOf("X:\"))
iList += 1
Next
End Function
@Andrii_Humeniuk Thank you for the help I had to tweak the code at line 67 to below to get it to not include any files that were under the reference files. Also I'm running into an error on line 45 but this only happens on some assemblies do you know what this could be from?
'If oOcc.SubOccurrences.Count <> 0 Then Call GetListComponents(oOcc.SubOccurrences, oListComp)
If oOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Or oOcc.Definition.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then
Else
End If
End If
