Hi @KWarrenCA . Now I modified the GetListComponents() function to work with Occurrences. Note that the current Occurrence check on lines 45-47 uses a GoTo statement to be able to process components in the middle of the current Occurrence, if you need to skip it and not read the components in the subassembly you need to replace GoTo SkipWritingList with Continue For
Sub Main()
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oDrawDoc As DrawingDocument = oDoc
Dim oSheet As Sheet = oDrawDoc.Sheets.Item(1)
oRevTableDateColumn = 1
If oSheet.RevisionTables.Count > 0
Dim oTable As RevisionTable = oSheet.RevisionTables.Item(1)
Dim oRows As RevisionTableRows = oTable.RevisionTableRows
Dim oRow As RevisionTableRow = oRows.Item(oRows.Count)
RevCheck = oRow.Item(oRevTableDateColumn).Text
Else
i = MessageBox.Show("Place a revision table!", "Need Revision Table", MessageBoxButtons.OK, MessageBoxIcon.Warning, MessageBoxDefaultButton.Button1)
Return
End If
If TypeOf oDoc Is DrawingDocument Then
If oSheet.DrawingViews.Count <> 0 Then
Dim oView As DrawingView = oSheet.DrawingViews.Item(1)
Dim oRefDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
If TypeOf oRefDoc Is AssemblyDocument Then
Dim oAssDoc As AssemblyDocument = oRefDoc
Dim oListComp As New Dictionary(Of String, Integer)
Dim oOccs As ComponentOccurrences = oAssDoc.ComponentDefinition.Occurrences
Call GetListComponents(oOccs, oListComp)
Dim sNameTable As String = "ACC LIST - " & System.IO.Path.GetFileNameWithoutExtension(oAssDoc.FullDocumentName)
Call CreatTable(oSheet, oListComp, sNameTable)
Call ExportList(RevCheck, sNameTable)
Call PID(RevCheck, sNameTable)
Else
MessageBox.Show("A table can only be created for AssemblyDocument.", "Error!", MessageBoxButtons.OK, MessageBoxIcon.Error)
End If
Else
MessageBox.Show("There are no DrawingViews on the first sheet.", "Error!", MessageBoxButtons.OK, MessageBoxIcon.Error)
End If
Else
MessageBox.Show("Active document is not Drawing Document.", "Error!", MessageBoxButtons.OK, MessageBoxIcon.Error)
End If
Events()
End Sub
Private Function GetListComponents(ByVal oOccs As ComponentOccurrences, ByRef oListComp As Dictionary(Of String, Integer))
For Each oOcc As ComponentOccurrence In oOccs
Dim oDoc As Document = oOcc.Definition.Document
Dim oDesign As PropertySet = oDoc.PropertySets("Design Tracking Properties")
If oOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Or
oOcc.Definition.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Or
oDesign("Cost Center").Value <> "ACC" Then GoTo SkipWritingList
Dim sStokNumb As String = oDesign("Stock Number").Value
'Dim folderpath As String = oDoc.PropertySets.Item("Design Tracking Properties").Item("Location").Value
Dim folderpath As String = oDoc.File.FullFileName
'defines backslash as the subdirectory separator
Dim strCharSep As String = System.IO.Path.DirectorySeparatorChar
'find the postion of the last backslash in the path
FNamePos = InStrRev(folderpath, "\", -1)
'get the file name with the file extension
Name = Right(folderpath, Len(folderpath) -FNamePos)
'get the path of the folder containing the file
Folder_Location = Left(folderpath, Len(folderpath) -Len(Name) -1)
'Sets export location for batch plot pdf location
Dim NewFilePath As String = "X:\7 - Design\0 - Batch Plot Drawings\" + Folder_Location.Substring(16) + "\"
If oListComp.ContainsKey(sStokNumb & NewFilePath) Then
oListComp(sStokNumb & NewFilePath) = oListComp(sStokNumb & NewFilePath) + 1
Else
oListComp.Add(sStokNumb & NewFilePath, 1)
End If
SkipWritingList :
If oOcc.SubOccurrences IsNot Nothing Then
If oOcc.SubOccurrences.Count <> 0 Then Call GetListComponents(oOcc.SubOccurrences, oListComp)
End If
Next
End Function
Private Function CreatTable(ByVal oSheet As Sheet, ByVal oListComp As Dictionary(Of String, Integer), ByVal sNameTable As String)
Dim oCustomTable As CustomTable
For Each otable As CustomTable In oSheet.CustomTables
If otable.Title = sNameTable Then
oCustomTable = otable
End If
Next
If oCustomTable Is Nothing Then
Dim oTitles(3) As String
oTitles(0) = "ACC #"
oTitles(1) = "STOCK NUMBER"
oTitles(2) = "QTY"
oTitles(3) = "HYPERLINK"
Dim oPlacementPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(.9525, 14.6288)
oCustomTable = oSheet.CustomTables.Add(sNameTable, oPlacementPoint, 4, oListComp.Count, oTitles)
oCustomTable.Columns.Item(1).Width = 2
oCustomTable.Columns.Item(2).Width = 6
oCustomTable.Columns.Item(3).Width = 2
oCustomTable.Columns.Item(4).Width = .001
oCustomTable.ShowTitle = True
'oCustomTable.TableDirection = kBottomUpDirection
'oCustomTable.HeadingPlacement = kHeadingAtBottom
oCustomTable.WrapAutomatically = False
'oCustomTable.MaximumRows=30
oHeightCustomTable = oCustomTable.RangeBox.MaxPoint.Y - oCustomTable.RangeBox.MinPoint.Y
oTablePt = ThisApplication.TransientGeometry.CreatePoint2d(.9525, oHeightCustomTable + .9525)
oCustomTable.Position = oTablePt
Else
If oCustomTable.Rows.Count < oListComp.Count Then
For i = oCustomTable.Rows.Count + 1 To oListComp.Count
oCustomTable.Rows.Add()
Next i
Else If oCustomTable.Rows.Count > oListComp.Count Then
For i = oCustomTable.Rows.Count To oListComp.Count + 1 Step -1
oCustomTable.Rows.Item(i).Delete()
Next i
End If
End If
Dim iList As Long = 1
For Each Item In oListComp
oCustomTable.Rows.Item(iList).Item(1).Value = iList
oCustomTable.Rows.Item(iList).Item(2).Value = Item.Key.Substring(0, Item.Key.IndexOf("X:\"))
oCustomTable.Rows.Item(iList).Item(3).Value = Item.Value
oCustomTable.Rows.Item(iList).Item(4).Value = Item.Key.Remove(0, Item.Key.IndexOf("X:\"))
iList += 1
Next
End Function
