I am wanting to have my sheet names enter automatically into my titleblock, but it is not a selectable "Text Parameter" to enter.
I am currently using a "Prompted Entry" to produce the Page Name in the titleblock, but would like to use what I name the sheet.
Any way this is possible?
Solved by HermJan.Otterman. Go to Solution.
I am working on a sheet naming system, I do not want to rename the sheets since I have formatted sheets doing that, I also have some iLogic that puts it in a Note on my cover page also groups and counts them based on their name. What I need to do is get the sheet name for each of them so that I can run an "If" statement that will abbreviate it and correspond to its number on the list. I am having issues with it not changing on each page, when I run the Rule it changes all Page names to the name that the rule is ran on. Any help would be great.
I'm trying to figure out the code that you have on this video you shared. I put the text property of sheet name as a prompted entry. When I make a 'New Sheet' it creates a new sheet with the Drawing sheet no. value that I input Eg: 000, W01, W02 etc. But this does not reflect the change on the sheet name located on the left menu bar. I want to have it done exactly just like how you showed in the video.
For Eg: "Sheet:1" can be renamed to "000" or "W01".... it should extract that information new value "000" as the sheet name right? It's not happening in my case and I wonder why?
did you download my drawing? in it is the iLogic code.
I think it is just the other way around.... you change the name in the browser, than you run the iLogic rule and it will change the titleblock info.....
HermJan.Otterman: How do you get the sheet number from appearing with the sheet name in the title block?
HermJan.Otterman: Also, is there a trigger you can put inside the code to make it automatically run?
There isnt a native way of doing that but if you're populating your titleblock by code, you can use these
Get the sheet name without the number
Private Function GetSheetName(ByVal SheetName As String, ByVal Splitter As String) As String
Return SheetName.Substring(0, SheetName.IndexOf(Splitter))
End Function
to use
Dim GetNameOnly As String = GetSheetName(oSheet.Name, ":")
Get the sheet number without the name
Private Shared Function GetSheetNumber(ByVal SheetName As String, ByVal Splitter as string) As String
Return SheetName.Substring((SheetName.IndexOf(Splitter) + 1))
End Function
To use
Dim GetNumberOnly As String = GetSheetNumber(oSheet.Name, ":")
or
Dim GetNumberOnly As Integer = Convert.ToInt32(GetSheetNumber(oSheet.Name, ":"))
You could also call them inline in your current method like this but Functions are better because they are sharable with other Methods
Dim GetNumber As Integer = Convert.ToInt32(oSheet.Name.Substring((oSheet.Name.IndexOf(":") + 1))
Hope that helps
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
this was asked before, please read from message 13.
or try the code of MachitoMax
If I want to keep the title blocks for some sheets is there a way I can have it not delete those out and replace it with the title block that is ilogic is using. I was thinking this might not be necessary for the other sheets with a different title block but im not sure.
