Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Set property file name
5 REPLIES 5
J.Classens
383 Views, 5 Replies
I want to export the filename to an excel sheet.
Unfortunately the propertysets doesn't contain the filename.
We now use the partnumber property but we see it can be overwritten and with copy designs/ mirrors the partnumber sometimes doesn't get updated.
Now i use the set function to set a property.
For example:
            Set oPartNumProperty = oCompDef.Document.PropertySets _
                .Item("Design Tracking Properties").Item("Part Number")
Now i want to do this with filename of the document.
I tried to do it like this but it doesn't work.
 Set oPartNumProperty = oCompDef.Document.FullFileName
Is it possible to set this property with the filename?
5 REPLIES 5
WCrihfield
in reply to: J.Classens
I'm assuming that the variable you are using in those examples is defined as (supposed to be representing) an iProperty (Inventor.Property) object itself, not just the Value of an iProperty, so the line in your first example would be OK, but the second example is trying to assign a Value (String) to that variable, which won't work.  It would have to be formatted more like this:
oPartNumProperty.Value = oCompDef.Document.FullFileName
(...after you have already defined the oPartNumProperty variable, and have already set it to represent that specific property object.)
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS :light_bulb: or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
J.Classens
@WCrihfield
This doesn't do the trick unfortunately.
This is the complete code.
Public Sub BOM_Export()
    ' Set a reference to the assembly document.
    ' This assumes an assembly document is active.
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oTemplate As String: oTemplate = "I:\Engineering\Formulieren en lijsten\Spare & wear parts lijst\MAXXXXXX-MAA.0000XXXXX-ORDERNO_YYYYMMDD.xltx"
    ' Set a reference to the BOM
    Dim oBOM As BOM
    Set oBOM = oDoc.ComponentDefinition.BOM
    ' Set whether first level only or all levels.
    oBOM.StructuredViewFirstLevelOnly = False
    ' Make sure that the structured view is enabled.
    oBOM.StructuredViewEnabled = True
    'Set a reference to the "Structured" BOMView
    Dim oBOMView As BOMView
    Set oBOMView = ThisApplication.ActiveDocument.ComponentDefinition.BOM.BOMViews.Item("Structured")
   ' Dim oBOMView As BOMView
   Set oBOMView = oBOM.BOMViews.Item("Structured")
   Call oBOMView.Sort("Item", True)
    Dim oPartNumProperty As String
    oPartNumProperty = oDoc.ComponentDefinition.Document.PropertySets( _
        "Design Tracking Properties")("Part Number").Value
    Dim oPartRevNum As String
    oPartRevNum = oDoc.ComponentDefinition.Document.PropertySets( _
        "Inventor Summary Information")("Revision Number").Value
    Dim oPartTitle As String
    oPartTitle = oDoc.ComponentDefinition.Document.PropertySets( _
        "Inventor Summary Information")("Title").Value
    ' set excel app and add worksheet
    Dim xlApp As Object
    Dim xlwb As Object
    Dim xlws As Object
    Set xlApp = CreateObject("Excel.Application")
    Set xlwb = xlApp.Workbooks.Open(oTemplate)
    'Set xlwb = xlApp.workbooks.Add
    Set xlws = xlwb.Worksheets(1)
    xlApp.Visible = True
    ' write more stuff
    ' xlws.Cells(1, 2) = oPartTitle
    ' xlws.Cells(1, 3) = oPartNumProperty
    ' xlws.Cells(1, 4) = "Rev: " & oPartRevNum
    xlws.Name = "Export list " & oPartNumProperty
    'Initialize the tab for ItemNumber
    Dim ItemTab As Long
    ItemTab = -1
    Dim oStartRow As Integer: oStartRow = 2
    Call QueryBOMRowProperties(oBOMView.BOMRows, ItemTab, xlApp, xlwb, xlws, oStartRow)
End Sub
Private Sub QueryBOMRowProperties(oBOMRows As BOMRowsEnumerator, ItemTab As Long, ByVal xlApp As Object, ByVal xlwb As Object, ByVal xlws As Object, oStartRow As Integer)
    ItemTab = ItemTab + 1
    ' Iterate through the contents of the BOM Rows.
    Dim i As Long
    For i = 1 To oBOMRows.Count
        ' Get the current row.
        Dim oRow As BOMRow
        Set oRow = oBOMRows.Item(i)
        'Set a reference to the primary ComponentDefinition of the row
        Dim oCompDef As ComponentDefinition
        Set oCompDef = oRow.ComponentDefinitions.Item(1)
        Dim oPartNumProperty As Property
        Dim oPartTitle As Property
        Dim oPartDescription As Property
        Dim oPartMaterial As Property
        Dim oPartVendor As Property
        Dim oPartStatus As Property
        Dim oPartFile As Property
        Dim oPartArticleNo As Property
        Dim oPartSurface As Property
        Dim oPartSurfaceValue As Property
        Dim oPartSpare As Property
        Dim oPartWeld As Property
        If TypeOf oCompDef Is VirtualComponentDefinition Then
            Set oPartTitle = oCompDef.Document.PropertySets _
                .Item("Inventor Summary Information").Item("Title")
            Set oPartDescription = oCompDef.Document.PropertySets _
                .Item("Design Tracking Properties").Item("Description")
            Set oPartMaterial = oCompDef.Document.PropertySets _
                .Item("Design Tracking Properties").Item("Material")
            Set oPartVendor = oCompDef.Document.PropertySets _
                .Item("Design Tracking Properties").Item("Vendor")
            Set oPartStatus = oCompDef.Document.PropertySets _
                .Item("Design Tracking Properties").Item("User Status")
            'Set oPartFile = oCompDef.Document.Property.Name(FileName)
            On Error Resume Next
            Set oPartArticleNo = Nothing
            Set oPartArticleNo = oCompDef.Document.PropertySets _
                .Item("Inventor User Defined Properties").Item("Article No")
            Set oPartSurface = Nothing
            Set oPartSurface = oCompDef.Document.PropertySets _
                .Item("Inventor User Defined Properties").Item("Surface Treatment")
            Set oPartSurfaceValue = Nothing
            Set oPartSurfaceValue = oCompDef.Document.PropertySets _
                .Item("Inventor User Defined Properties").Item("Surface Treatment Value")
            Set oPartSpare = Nothing
            Set oPartSpare = oCompDef.Document.PropertySets _
                .Item("Inventor User Defined Properties").Item("SpareWear")
            Set oPartWeld = Nothing
            Set oPartWeld = oCompDef.Document.PropertySets _
                .Item("Inventor User Defined Properties").Item("Weld Assembly")
                xlws.Cells(oStartRow + b, 1) = oRow.ItemNumber
                xlws.Cells(oStartRow + b, 2) = oPartNumProperty.Value
                xlws.Cells(oStartRow + b, 3) = oRow.ItemQuantity
                xlws.Cells(oStartRow + b, 4) = oPartArticleNo.Value
                xlws.Cells(oStartRow + b, 5) = oPartTitle.Value
                xlws.Cells(oStartRow + b, 6) = oPartDescription.Value
                xlws.Cells(oStartRow + b, 7) = oPartMaterial.Value
                xlws.Cells(oStartRow + b, 😎 = oPartSurface.Value
                xlws.Cells(oStartRow + b, 9) = oPartSurfaceValue.Value
                xlws.Cells(oStartRow + b, 10) = oPartVendor.Value
                xlws.Cells(oStartRow + b, 11) = oPartSpare.Value
                xlws.Cells(oStartRow + b, 12) = oPartStatus.Value
                xlws.Cells(oStartRow + b, 13) = oPartWeld.Value
                xlws.Cells(oStartRow + b, 14) = oPartFile.Value
        oStartRow = oStartRow + 1
        Else
            'Get the file property that contains the "Part Number"
            'The file property is obtained from the parent
            'document of the associated ComponentDefinition.
                 ' write more stuff
            Debug.Print Tab(ItemTab); oRow.ItemNumber; Tab(17); oRow.ItemQuantity; Tab(30); _
                oPartNumProperty.Value; Tab(70); oDescripProperty.Value
            'Recursively iterate child rows if present.
            If Not oRow.ChildRows Is Nothing Then
                Call QueryBOMRowProperties(oRow.ChildRows, ItemTab, xlApp, xlwb, xlws, oStartRow)
     Next
    ItemTab = ItemTab - 1
End Sub
The macro wil export our BOM list to a excel sheet.
In this macro we export te Partnumber.
The following rule wil do this trick.
 What would i have to do to export de filename of each BOM list rule instead of the part Number.
Any suggestions?
WCrihfield
This is confusing because the same variable is being used for two different types of objects in the same macro.  In the  BOM_Export routine it is defined as a String object, and correctly doesn't use the term 'Set' when setting its value, but in the QueryBOMRowProperties routine it is defined as a Property and correctly uses the 'Set' term to set its value.  In your original post I had no idea what Type you had defined that variable as.  The Object/Data Type of the Value you assign to a variable must match the Type of the variable.  So if you want to set a document's FullFileName to a variable, that variable must have either been pre-defined as a String, or not been pre-defined yet at all.   I personally wouldn't use the a variable named "oPartNumProperty" to store the FullFileName, because it doesn't make sense to me, but it's not my code, so as long as it all makes sense to you, that's all that matters.  Maybe just create an additional String type variable, just for storing the FullFileName, then have one or more alternate lines of code that are commented out, so you can switch back and forth between using Part Number and FullFileName in your process.
Something like this:
oFullFileName = oCompDef.Document.FullFileName
where the variable "oFullFileName" either has not been created/defined yet, or has been created/defined as a String.
I did notice though that one of your lines of code that is writing data to Excel (same in both Subs) appears to be missing some data.
This line:
xlws.Cells(oStartRow + b,  = oPartSurface.Value
seems like it should be like this:
I guess it won't even let me fix this or type it correctly, because it keeps converting the text into an emoji of a face with sunglasses in place of the digit 8 followed by the ) symbol.
Wesley Crihfield
J.Classens
in reply to: WCrihfield
Thanks that does the trick!
I only have one problem now, i thought i needed the full file name.
I didn't realized this includes the complete path.
When i tried FileName instead of FullFileName i get a "Object doesn't support this property or method"
I can't find the right name to get only the file name.
Is it possible to get only the FileName?
The 8   ) that was missing was deleted when i copied it. In the macro it was still there.
The complet code looks now like this:
    Dim oTemplate As String: oTemplate = "I:\Engineering\Formulieren en lijsten\Spare & wear parts lijst\MAXXXXXX-MAA.0000XXXXX-ORDERNO_YYYYMMDD.xltm"
    Dim oBOM As BOM
    Dim xlApp As Object
    Dim xlwb As Object
    Dim xlws As Object
    ' write more stuff
    Dim ItemTab As Long
    ItemTab = 2
End Sub
    Dim i As Long
        Dim oRow As BOMRow
        Dim oFileNameProperty As String
            oFileNameProperty = oCompDef.Document.FullFileName
                xlws.Cells(oStartRow + b, 2) = oFileNameProperty
        Else
                 ' write more stuff
     Next
End Sub
JelteDeJong
this iLogic rule is an example of getting just the filename (without extension)
Dim doc As AssemblyDocument = ThisDoc.Document
Dim oBOM As BOM = doc.ComponentDefinition.BOM
Dim oBOMView As BOMView = oBOM.BOMViews.Item("Structured")
oBOMView.Sort("Item", True) For Each oRow As BOMRow In oBOMView.BOMRows Dim oCompDef As ComponentDefinition = oRow.ComponentDefinitions.Item(1)
' options for getting the filename Dim fullFileName As String = oCompDef.Document.FullFileName Dim fileName = IO.Path.GetFileName(fullFileName) Dim FileNameWithoutExtension = IO.Path.GetFileNameWithoutExtension(fullFileName) Logger.Info(fullFileName) Logger.Info(fileName) Logger.Info(FileNameWithoutExtension) Logger.Info("-------------------------------") Next
Jelte de Jong
Blog: hjalte.nl - github.com
