Server error for unknown reason during check-in Vault 2019
Message 1 of 10
Hello, guys.
An assemble that had no trouble thus far, I've got this message now while I proceed check in.
Could you help me?
Replies (9)
Message 2 of 10
bradeneuropeArthur
hi,
uncheck the dwf creation on check in...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 10
How can I uncheck the DWF file? I can't seet it on Vault.
I tried to undo check out, but the message of error remains the same.
Message 4 of 10
bradeneuropeArthur
In the vault options dialog settings.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 10
bradeneuropeArthur
Within inventor!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 10
JamieVJohnson2
Inventor - Vault Add-in has a prompt options (Vault Ribbon\File Status section \ Vault Options \ .Check In dialog, Settings...  \ Visualizationg Attachment Options \ Do no create.  You can set a prompt option to do that (done so in the past), but if you're not careful you may default yourself out of the options you want.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
Message 7 of 10
I have accessed those dialog boxes, but the message of error persists.
Message 8 of 10
bradeneuropeArthur
Maybe you try to edit a Library file with the Vault project file.
Since this is not possible you receive this error!
Opening and editing library files needs to be done with a separate project file.
Is this the case for you too?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 10
david_coulam
Does this have to do with special characters (international?) like this issue for prior versions of Inventor?
Message 10 of 10
david_coulam
Also, make sure the Vault file store folder is not full.
